Old 2012.10.28, 05:53 AM   #1
targetingxmod
BMW Z-mod by ©targetingxmod
BMW
Setup for carpet track:
-Front Diff almost locked, +100wt silicone oil on diff gears (makes cornering much more controlled)
-Rear Diff almost loose, just normal lithium 1:1 grease on diff gears (makes cornering much more conttrolled)
-Front springs stiff (Blue ones from Xmods kits) (makes steering better and controled)
-Rear Springs medium (Yellow ones from xmods kits) (makes steering on the back, easy, for the front)
-Front Tires more then 30ş. Medium soft compound. (in here, softer will turn agressevely, hard will not steer at all.....)
-Rear Tires really soft to grip, less then 10ş. Softer or very soft compound (GRIP an more grip, always needed for control)
Photos:
targetingxmod is offline   Reply With Quote
Old 2012.10.28, 05:53 AM   #2
targetingxmod
-ON/OFF removal
-Bigger cables all over, give the same effect as removing on/off (more power)
Need to:
-Keep the motor and put on a neodium can with bearings...
-Ceramic bearings for the car
-CF central shaft
It's so so light....now... with those... let's it the track!!
Can't believe the kick i got for the stock xmod motor!!
Fet's help, but larger cables and removing ON/OFF help to!!
Old 2012.11.12, 08:38 AM   #3
targetingxmod
-Got the CF shaft, so now i am going to try the ceramic bearings...
Result?
Well, it's noticable!
Videos:
http://www.youtube.com/watch?v=dOdXt...ature=youtu.be
http://www.youtube.com/watch?v=rn78F...ature=youtu.be
Keeping the stock motor, just need a BB can for it and neo mags! On the videos the Ceramic bearings were not yet installed!
Old 2013.01.05, 03:00 PM   #4
targetingxmod
-Last time you see this on the bimmer...
-2.4ghz electrics. Wiring is selfexpanatory for both AM and 2.4ghz!
For motor wiring...
Well over the years i saw major improvement on "nuts" fat cables for those 130can's! Yep, no heat issues more! YES! If you are getting heat, it's somewhere else on the drivetrain or "nuts" +17t pinion, lol
Old 2013.10.01, 06:59 AM   #5
targetingxmod
Videos:
http://www.youtube.com/watch?v=dOdXt2NiRhw
http://www.youtube.com/watch?v=rn78ForXWdg
Suggestion for PNWC 2011 Cherub1m PN Racing World Cup 67 2010.10.11 10:21 AM
BMW E30 and 360 GTC From JO67 jo67 Custom Bodies 7 2007.06.12 10:34 AM
Transposed brush mod for the ATOMIC bb can.... ph2t Motor Tech 3 2007.01.07 09:01 PM
