Old 2012.12.11, 08:57 AM   #1
HammondCheese
Pressure plates for Atomic 2wd Diffs
Hi,
I've got a 2WD Atomic diff thats about 12 months old and in need of a rebuild. Its got the d-style pressure plates but I cant seem to see them listed on the Atomic site any more (or 2 other Atomic stockists). Are the D-Style plates no longer made? The only 2wd plates I could see were the round style AR-070. These kind of fit with a tiny bit of play but arent ideal. Any suggestions as to what plates to use?
This leads to a related question - what style plates do the V-III diffs (ie AR-270) use? Anyone?
HammondCheese is offline   Reply With Quote
Old 2012.12.11, 10:36 PM   #2
Atomic-USA
Customer/dealer support
Correct, these rings are no longer being sold as replacement. These rings can be re-finished using high quality sand paper from Tamiya for example.
www.rcatomic.com
Old 2012.12.12, 10:17 PM   #3
HammondCheese
Thanks for the fast response - I'll give it a shot. Does this mean that the current diffs use the standard round style plates eg AR-070?
Thanks again.
Old 2012.12.12, 10:59 PM   #4
Atomic-USA
No, all current Atomic diffs use the same D-ring.
The pressure plates will be as good as new after polishing; there is no real need to replace them.
www.rcatomic.com
Jomurena Pressure plates Rune New Products 7 2011.03.13 10:29 AM
PN Racing Mini-Z 2WD Machine Cut Delrin Limited Slip 64P Spur Gear 51T-54T PNracing PN Racing 71 2010.04.03 04:24 AM
Stock AWD Gear Diffs - Dry or with 15k grease? Felix2010 Mini-Z AWD MA-010, MA-015 12 2009.08.10 12:05 AM
