Old 2014.02.17, 05:01 AM   #16
imxlr8ed
imxlr8ed's Avatar
At the suggestions of a hardcore racer and a fellow part designer, I have uploaded 3 new plate sets for the MR03.
If you've seen the previous sets, you know they come in 6 widths per set, these new sets will allow the buyer to get 6 of their preferred widths in one shot.
#6 being the widest, #4 being the thinnest (I skipped the last three thinnest plates because I haven't received feedback on them as of yet... other than my own)
I will be breaking up my other sets and you may see some older sets go into an "Archive" section of my shop very soon. I'm doing this so you can still have access to the parts that either haven't sold well or have newer versions available.
You will notice an extra hole in the these new MR03 plate sets... but it's not my business to discuss!
http://www.howfastareyou.com
SUPPORT LBR!!!
(Local Basement Racing)
Old 2014.02.17, 12:53 PM   #17
Number1
Number1's Avatar
Hey. Ed, It's O.K. to share the idea, but if you are not comfortable telling what the hole is for, then I'll do it for you, free of charge, of course.
I've set up my car with a screw at the last hole on the chassis since day one. There are two benefits of using this set up:
1): With that screw, I can eliminate the use of the shock and reduce some weight at the top.
2): T-plate of different width/thickness will have different flex, if you change your T-plate from a thick one to a thin one, you will notice the chassis will sag. With that screw, you can adjust the sag/pre-load, that in turn, also adjust ride height(just a tiny bit, don't go crazy here though). Without that hole, you may need to put back/ remove the T-plate a few time before you get it right. With a hole on the T-plate, you simply run your wrench thru the hole and make the adjustment.
Will a chassis setup with sag or preload handle differently? Well, it's up to u to find out.
Lastly, will I endorse this T-Plate?
What do you think what I'm doing here?
MIni-z racing on YouTube:
http://www.youtube.com/user/Nnumbberrone
Number1 is offline   Reply With Quote
Old 2014.02.17, 02:18 PM   #18
imxlr8ed
imxlr8ed's Avatar
Thanks Roland!
Huge thanks for the endorsement!
(and the tip... now the whole world knows! )
SUPPORT LBR!!!
Old 2014.02.17, 06:59 PM   #19
lfisminiz
lfisminiz's Avatar
Still nice to have a "pro" endorse them.
UID F1 Side Plate Set... imxlr8ed Useful Idiot Design 7 2013.12.28 01:28 AM
UID MR03 (Wide) Tie Rod Set... imxlr8ed Useful Idiot Design 12 2013.03.02 12:25 AM
Pressure plates for Atomic 2wd Diffs HammondCheese Atomic 3 2012.12.12 09:59 PM
FS: Stanced F430 MR03 color01 Mini-Z Marketplace 0 2012.09.16 07:19 PM
FS: Ultimate MR03 RTR competition package MR-03 Kyosho Ricochet Mini-Z Marketplace 0 2012.03.01 11:23 PM
