Old 2014.02.24, 09:46 PM   #16
TheSteve
VE7FM
Originally Posted by KWT View Post
I would be interested in your home brew solution if you don't mind sharing.
Not a problem at all. I started a post with the info, just need to draw up a diagram of how the resistors and diode are connected.
http://mini-zracer.com/forums/showthread.php?p=450350
Old 2014.03.08, 07:53 PM   #17
goflyingbear
I can not read or write. I get this error message from the app.
goflyingbear is offline   Reply With Quote
Old 2014.03.10, 12:03 AM   #18
goflyingbear
Apparently the PN board can only read/write with PN's ICS software. The android app only works for kyosho PCBs.
I bought a bluetooth adapter for my PC, connected to the PN bluetooth adapter, and was able to read/write normally using the PN ICS 1.0 software.
Old 2014.03.10, 09:51 AM   #19
lfisminiz
lfisminiz's Avatar
As far as i know, the Android app is being worked on to use this.
Old 2014.03.13, 03:48 PM   #20
yasuji
PN RacingTEAM Driver
yasuji's Avatar
ok... fyi the android software for miniz and ve is made by a awesome miniz enthusiast in japan and not made specifically for pnracings Bluetooth adapter
and we appreciate his efforts in introducing this tooling in to the miniz world
the pnracing android software is coming soon...
the pnracing Bluetooth adapter works flawlessly on the pnracing electronics when connected to a Bluetooth equipped laptop
for the current android software we have found THE solution to the ERROR PROBLEM
please remove the white wire from the plug entirely, just cut it out...
it is a secondary write wire that is unnecessary for the miniz
and apparently it is unnecessary for the pn software as well
Grant "Yasuji" Matsushima
www.pnracing.com
gm@pnracing.com
Old 2014.03.14, 07:34 AM   #21
briankstan
SLMZ / HFAY
briankstan's Avatar
thanks for the info grant, I'll give is a shot and see if the error message goes away. I've been getting the error message but have confirmed that the setting are being written to the board, at least that is how mine has been working.
briankstan is online now   Reply With Quote
Old 2014.03.14, 10:12 AM   #22
yasuji
yasuji's Avatar
yes we was getting the same when we were using the usb dongle...
www.pnracing.com
gm@pnracing.com
Old 2014.03.24, 09:39 AM   #23
briankstan
SLMZ / HFAY
briankstan's Avatar
just to confirm, I pulled the white wire from the plug and I'm not getting the write error message any longer, I get a "write ok" message now.
thanks for posting that info Grant.
Old 2014.03.24, 09:59 AM   #24
yasuji
yasuji's Avatar
very cool! glad to hear it!
www.pnracing.com
gm@pnracing.com
Old 2015.01.23, 07:43 AM   #25
hasse85
hello everyone..
I bought today this adapter and I get the same error message ..
I use a standard MR03 short, so the only thing I need to do is to cut away the white wire from my PN Bluetooth adapter, so will it work then?
uses android app MiniZ ICS BT1.5
Mini-z Mr03 PN-Racing products 70T stockcar
Mini-z MR03 PN-Racing products 50-43T MODcar
Team Driver : RadicalRides PN-Sweden
hasse85 is offline   Reply With Quote
Old 2015.01.23, 09:57 AM   #26
briankstan
SLMZ / HFAY
briankstan's Avatar
Originally Posted by hasse85 View Post
hello everyone..
you can simply remove the wire from the connector instead of cutting it.
I did this and mine works without issue.
Old 2015.01.23, 04:24 PM   #27
hasse85
thank you for the replay, i will try that
Old 2015.01.25, 11:11 AM   #28
hasse85
well now i have tried once again, i removed the white wire and did a new try, BUT i still get the same error message..
ICS Failure board size error.
docent matter what i do, it's just the same message over and over again,
i did try on a different car also but still the same error message..
i use Kyosho MR03 board with the PN ICS adapter and it dosen't work at all..
can someone please tell me what i'am doing wrong here??
when i start the program and sets the power to the car, the Green led comes on, and when i am making my new profil and want to save it, the error message comes.
// Hasse
Old 2015.01.25, 02:08 PM   #29
KWT
Try this. Plug in the adapter while the car is off. While pushing down on the pairing button, turn car on. Then start up the program and do a read. Make sure that the correct model is selected, then make changes and do a write.
Old 2015.01.27, 01:47 PM   #30
hasse85
i will try that,
thanks for the advise
March 26, 2011 - Reflex Racing Series Mike Keely The Track, Gaithersburg MD 13 2011.03.27 08:24 PM
WTB: ICS Multi Setting Adapter & Setting Card Hekyl Mini-Z Marketplace 0 2009.05.14 07:57 PM
Inside Line Racing Anniversary Race Z_408 Events 3 2008.09.15 03:15 PM
Intercontinental Racing using 3D RC Racing Blackno3 Red Hill Games 3D RC Racing 0 2008.02.26 06:44 PM
FS/T: KYOSHO / PN RACING PARTS MR01/F1/Overland kryten Mini-Z Marketplace 4 2008.02.19 05:09 PM
