Old 2014.11.05, 04:06 PM   #31
zround
Originally Posted by NoBrainer View Post
The color scheme for the secondary monitor?
Because that is available and working for me and others.
I'm learning Championship Manager, and maybe I can help with that later in the year after some experience.
Everybody are welcome to contribute to have a good ZRound Library. Please contact to me by mail to assign a user with rights for writing.
Old 2014.11.05, 05:41 PM   #32
NoBrainer
NoBrainer's Avatar
Thank you sir
Old 2014.11.05, 06:51 PM   #33
NoBrainer
NoBrainer's Avatar
Championship Manager - Heats and Main
How can I make
qual 1 heat a
qual 1 heat b
etc?
Also for main
main 1 heat a
main 1 heat b
We are not many drivers, 4-8 pr heat.
But we tend to set up qual 1 a and b and run 3 quals.
Then we maybe run Main C with bump up to B and Main B with bump up to A.
Old 2014.11.05, 07:00 PM   #34
NoBrainer
NoBrainer's Avatar
I can only add 5 races in the Championship manager.
If I at least could create 8, I can create a season of racing.
So that we can make the championship before we start a season and export it to all the places we drive.
If there is to be a limit, maybe 12 (1 for each month) would be better?
It might be better to make all the rounds in advance, so that we don't have to make time for that when we just want to drive.
We drive at several different places with 1 hour or more of transport between the tracks
Also, in the FIND CHAMPIONSHIP, I would like a comment field. So that I could explain the template I made for later use.
Like this:
Class: MiniZ Racer
Championship: MZN Stock
Comment: Stock 2wd, 3 quals 5 min, 3 finals 8 min, bump up 2
Old 2014.11.06, 03:35 PM   #35
zround
Check the "Number of races" setting.
You can add up to the number of races configured. The default value is 5.
The recommended procedure is to share the "datos" folder. Once a race finishes on a place, the datos folder is sent to the next one. The full championship results will be on the same database and championship ranking is up to date every time.
There is not such limitation as said before.
The number of heats depends on the racers registered into the race. If you know who will run on every race, you can register them and prepare the race at home.
Like this:
Class: MiniZ Racer
Comment: Stock 2wd, 3 quals 5 min, 3 finals, min, bump up 2
Suggestion noted down.
Old 2014.11.17, 04:57 AM   #36
NoBrainer
NoBrainer's Avatar
Yes, thanks for the tip.
Think I got it to work now.
But, when you create a championship, you can set up ex 5 races and then discard 1.
Is it the same with the the qual and final in every race?
Like if I want pre-qual, 3 quals and 3 finals.
Can I have the championship manager to discard the worst qual and the worst finale for each driver?
Old 2014.11.17, 04:54 PM   #37
zround
Heats and Mains can be configured to count the n-best rounds in order to compute the qualify/final results.
The setup on the championship will be applied by default on its races. However, you can overwrite the default values on the race once it is created.
Regards.
ZRound Companion application for the BlackBerry PlayBook Sinister_Y ZRound 12 2012.11.14 10:17 AM
ZRound Suite update 1.10.10 zround ZRound 1 2011.09.14 02:06 AM
ZRound Suite update 1.10.4 zround ZRound 4 2011.02.06 04:36 AM
ZRound Suite update 1.9.8 zround ZRound 0 2010.05.08 02:15 AM
ZRound Suite 1.9 zround ZRound 10 2010.02.19 12:25 PM
