Go Back   Mini-ZRacer.com Forums > General Discussion > New Products
Old 2014.03.20, 08:30 PM   #1
PNracing
Send a message via AIM to PNracing Send a message via Yahoo to PNracing Send a message via Skype™ to PNracing
PN NEW Constant Power Ni-MH Rechargeable AAA Battery (4pcs)
March 22 release $9.99
New CP888 batteries provide constant voltage output over time, with no drop-off after the first few minutes, ensuring consistent and lasting performance.
Ideal for powerful motors and endurance race where consistency is key.
Recommend charge at 0.7-1.0amp for the best balance between power and run time.
Spec:
AAA size
4pcs
http://www.pnracing.com
http://PNWC.pnracing com
DownloadPNICS ICS Android Apps for ICS Setting
PNracing is offline   Reply With Quote
Old 2014.03.20, 10:47 PM   #2
lfisminiz
lfisminiz's Avatar
Been trying them out....very good so far.
Old 2014.03.21, 01:57 AM   #3
dwight
battery
At what rate do you discharge them?
Also how do they compared to the peak 900?
dwight is offline   Reply With Quote
Old 2014.03.21, 06:05 AM   #4
lfisminiz
lfisminiz's Avatar
If you mean me...I usually discharge at 3 or 1. As far as Peaks...never used them much to tell you.
Old 2014.03.21, 01:04 PM   #5
briankstan
SLMZ / HFAY
briankstan's Avatar
I ordered a couple sets to give them a try. I've been very happy with the peak 900's so I'll give a good comparison between the two when I have a changed to get some laps in with them.
Old 2014.03.21, 07:41 PM   #6
Larry. What are you using to discharge at 3a?
Old 2014.03.21, 10:15 PM   #7
lfisminiz
lfisminiz's Avatar
I have some MuchMore dischargers. There made for different type of batts. I just modded them to fit the AAA batts. They work like the PN and other type dischargers. I dont think they are made anymore but can be found.
Old 2014.03.22, 07:42 AM   #8
Thanks Larry. Knew it couldn't be PN units since,I believe, they only discharge at half that?
Old 2014.03.22, 08:52 AM   #9
Mike Keely
When I match my batteries I use the Check Point or the Ice type charger. I match them with a 2.5 amp discharge. I use the Integ-y charging tray to hold the cell.
DG-Designs / Brooklyn Hobbies
Old 2014.03.22, 01:01 PM   #10
lfisminiz
lfisminiz's Avatar
Ya, I think the PN are 1 amp. Discharge.
Miniz Beginner/Common Q&A Aurora Beginner Questions 3 2012.09.09 09:51 AM
Apple Battery Charger arch2b Batteries, Chargers and Dischargers 5 2010.08.04 10:40 AM
New LRP VTEC Instant Power AA & AAA Battery Jorge_Jayena Parts and Hop-ups 5 2008.12.04 07:12 PM
PN Racing 800mah High Power Battery AAA Red Team Batteries, Chargers and Dischargers 5 2008.11.19 12:50 PM
Lacrosse BC-900 Alpha Power Battery Charger arch2b Batteries, Chargers and Dischargers 41 2007.10.24 07:25 PM
