Old 2014.08.16, 11:27 PM   #46
Felix2010
Thanks for the vid bye-bye! Awesome stuff
*** TOP SECRET MOTORS ***
[FONT="Book Antiqua"]
Old 2014.08.17, 08:36 AM   #47
byebye
byebye's Avatar
after 10-15 laps I was able to dial in the steering and throttle and such. The servo moves quite a bit. I put a little double sided tire tape but that didn't help much. Needs to be a bit thicker.
Old 2014.08.18, 11:12 PM   #48
scoobyrs25
My servo broke on the first lap. Any ideas on a quality substitute?
scoobyrs25 is offline   Reply With Quote
Old 2014.08.21, 01:39 PM   #49
yamar6
They say the aluminum servo holder helps a lot. I just ordered one I'll tell u if it works should have it in a couple days
yamar6 is offline   Reply With Quote
Old 2014.08.21, 11:09 PM   #50
dameetz
dameetz's Avatar
I m using Futaba S3154, sizewise its a direct fit, its plastic gear, i only broke the gear once after using it about 4 months now but thats because i was testing the car without the body. Just make sure you are not using excessive front wheel offset so that the wheels are not protuding beyond the fender. Some of my friends are using Savox metal gear servo, they are durable however its not a direct fit, need modification of the servo mount and its a tight fit between the servo and the motor endbell.
Old 2014.08.21, 11:13 PM   #51
dameetz
dameetz's Avatar
For triple security and rigidity, i m using the alum mount, double sided strong acrylic tape and longer screws to mount the servo to the chassis. No more wondering during the straight after that.
Old 2014.08.23, 01:46 PM   #52
yamar6
Good to know just waiting cause miniz store ran out I had to order from eBay from china
Old 2014.09.04, 02:40 PM   #53
dwight
Amz
So I have the gogo lap and it's working with the EX 1 seams fine will give more details on Saturday when I go to the local track.
dwight is offline   Reply With Quote
shop.tinyrc.com: $149.99 MR-03 Body & Chassis Set & KT-18's In Stock! Mrs Mini-Z Mini-ZRacer.com Announcements 0 2011.03.25 10:21 AM
Kyosho MA-01 Set Up Thread pchan0 Mini-Z AWD MA-010, MA-015 6 2006.08.09 03:47 PM
Roll Shock Set, Main Shock set + graphite H bar Unistar Parts and Hop-ups 6 2001.12.18 11:33 PM
Roll Shock Set VS Side Shock Set - whats the difference? Unistar Parts and Hop-ups 4 2001.12.07 11:51 AM
