Old 2014.07.30, 01:16 PM   #1
yellowdog
Question mr03ve board failure
Hi, I'm a new comer here. I just bought a new mr03ve PCB and this is my second car assembled. However, the pcb board seems weired. I can successfully pair with the car, but not everytime the car can get connected with the transmitter after pairing. I need to on and off the car and transmitter to bind them together for at least several times.
I have another car which can bind with the transmitter everytime under the same environment. As a result, I think that should not be a problem on transmitter itself. Is there any idea about that? thanks.
yellowdog is offline   Reply With Quote
Old 2014.07.30, 01:33 PM   #2
TheSteve
VE7FM
Hi there and welcome to the forum!
I have found the mr03ve board is pickier at establishing a connection with a transmitter compared to a regular mr03 board. Keeping the car and transmitter a few feet apart when powering on helps. If the connection doesn't work after a few seconds I turn the power to the car on and off again and generally it connects instantly - I rarely have to do this though.
Try having the car and transmitter further apart when powering on and let us know if it helps.
Tags
mr03ve bind pair
mr02 ex 2.4 ghz board question... herman Mini-Z Racer MR-02 11 2013.06.09 12:01 PM
Burned FET damaged board repair Action B Mini-Z Science 20 2012.01.17 01:13 AM
MA-010-MR-02 AD board set Conversion sciencemike Mini-Z AWD MA-010, MA-015 21 2009.08.16 03:09 PM
V2 Power Board TinRacers Atomic 1 2007.06.14 01:07 PM
MR-01/OL board with 5 cells miketre Mini-Z Science 4 2003.11.25 06:16 PM
