Old 2014.10.01, 08:59 AM   #1
cowboysir
PN brushless v2 and rotors?
I'm curious to find out if swapping the rotors (available seperate) in certain KV motors would change the overall KV?
For example, if I put a thinner rotor in a 5500kv motor would it then rotate to the same KV as a 7500?
Thanks for your time.
Old 2014.10.10, 10:43 PM   #2
cowboysir
Still curious to find out more about these replacable rotors:
1.I don't want to assume but in theory I see each motor built to a specific wiring layout and built with a standard 14.5mm rotor to get the KV ratings of 5500, 7500 and 9500.
So if i put 2 and 2 together and install a 15.5mm rotor into a 5500kv can with windings I would get a lower kv overall and more low end?
anyone got the skinny on this ?
Old 2014.10.11, 09:49 PM   #3
Felix2010
It only makes sense that swapping a smaller or larger diameter rotor into a brushless motor will change the Kv/RPM's --- The same way that swapping the armature or magnets in a brushed-type motor changes the overall RPM's of the motor, in addition to altering the torque output of the motor.
*** TOP SECRET MOTORS ***
[FONT="Book Antiqua"]
Old 2014.10.11, 09:55 PM   #4
cowboysir
True enough if I knew exactly which rotor came in which can. I'd like to get a 5500 but don't want to blow another $15 if it comes equipped with the 15.5mm rotor
Old 2014.10.11, 10:52 PM   #5
Felix2010
Ahh.. I see your point cowboysir...
Maybe email Philip @PN and ask him what size rotors come with the 3 different Kv PN V2 Brushless motors???
I also think it would be good to know whether the 5500 7500 9500 motors all come with 14.5mm rotors...
Old 2014.10.29, 04:52 PM   #6
Rune
Mini-Z Norway
Rune's Avatar
All V2's are delivered with 14,5mm rotor
Mini-Z Norway
Old 2014.10.29, 05:41 PM   #7
cowboysir
Excellent news Rune! I appreciate it...
Looks like I may try again with the VE.
Old 2014.10.29, 06:13 PM   #8
TheSteve
VE7FM
Yeah, like you need more motor...
Old 2014.11.23, 12:15 PM   #9
Racer-HH
Racer-HH's Avatar
Do you need to shim the other armatures differently from the standard 14,5 rotor?
[ my TX: EX-6 ]
Old 2017.08.01, 08:05 AM   #10
cowboysir
Thought I'd bump this up to see if anyone has data.... I've been almost curious enough to get a brushless motor checker and put together some data on rotor swaps in various PN brushless V2.
Chime in if you have physical test results?
Old 2017.08.04, 11:11 AM   #11
yasuji
PN RacingTEAM Driver
yasuji's Avatar
If i remember correctly it is approximately 1000 kv per mm
I have tested with std 14.5 an 13.5 12.5 and 15.5 in 5500kv as well as 7500 using lithium and 9500 nimh
The one thing that I noticed is that the smaller rotor is less punchy with more rip to the peak
For the most part it us a good set if tools to have in the arsenal to fine tune the charectisic for your driving style
For me... on the 9500 nimh I prefer the 13.5 rotor
For 5500 lithium 12.5 or 13.5
For 7500 lithium 14.5 std
Hope this helps
Grant "Yasuji" Matsushima
www.pnracing.com
gm@pnracing.com
Old 2017.08.04, 07:54 PM   #12
cowboysir
thanks Grant... that's some of the information I was hoping to find.
I'm not much for li-po racing at this scale so I think I've got some testing to do at 4.8v.
Old 2017.08.05, 01:30 AM   #13
yasuji
yasuji's Avatar
The newest thing we have been doing at kenon is 5500kv nimh vs 3500kv lithium.... cars are about even with open gearing
www.pnracing.com
gm@pnracing.com
Old 2017.08.17, 10:19 PM   #14
Grant, how does the change in rotor effect the off throttle characteristic? Does the increase in mass moving to a larger rotor decrease the drag brake and vice versa?
Been a while since I've played mini-z, thinking of finally building up my brushless car...
Old 2017.08.17, 10:26 PM   #15
yasuji
yasuji's Avatar
Bigger magnet more torqe and slightly more drag brake smaller magnet less punch smmth rip to the top
www.pnracing.com
gm@pnracing.com
