Old 2014.11.20, 11:58 AM   #1
Midlifekyoshorc
Ko propo ex1 KIY help
Hello, I just bought a few dnanos and a mini z so also bought a ver3 KIY transmitter.
I ran into the common problem of no reverse after pairing my dnano. Took a little searching but found the info in the dnano instruction which is intended for the kyosho kt18 transmitter.
So what trim should I use to adjust the neutral position way it will go into reverse? Should I use the sub trim or the TH trim?
Also should I use the settings in the sticky for the dnano or mini z even though I'm not using a module with the transmitter?
Sorry for being such a noob but it's something we all go through when getting into this hobby I suppose. There just isn't hardly any info out there to read or watch with Ko propo and dnano.
Midlifekyoshorc is offline   Reply With Quote
Ko Propo EX-1 KIY unwritten Mini-Z Marketplace 3 2014.08.13 02:53 PM
FT: New KO Propo EX-1 KIY V3 ASF lgibjones Mini-Z Marketplace 0 2014.01.02 10:45 PM
Fs: EX1 KIY chad508 Mini-Z Marketplace 4 2013.08.04 10:16 PM
PN 4D trigger for ko propo ex-1 KIY? Christopher Rc KO PROPO 5 2012.10.31 11:32 AM
FS: Ko Propo EX1 UR TX ONLY Ronac Mini-Z Marketplace 2 2010.04.22 03:32 PM
