Old 2015.01.03, 07:09 PM   #1
TheRinger
THATS HOW I ROLL
TheRinger's Avatar
X-power adjustable front end
Has anyone tried the X-power adjustable front end?
You can adjust camber, caster and ride height with it.
Part #xp-m03-c36-bk on their website.
Awesome RC Racing R.I.P
Old 2015.01.03, 10:10 PM   #2
dwight
It works just need shims by the upper arms
dwight is offline   Reply With Quote
Old 2015.01.03, 10:50 PM   #3
DMALMAD
DMALMAD's Avatar
Many guys have tried it at my local track. Although I personally don't have it the guys that do use have said that they get more front grip with it. I don't know if that is necessarily true because it looks like their front end gives much more static camber whereas the pn dbl aarm gives more reactive camber. SO based on theory and what I have seen it gives a little more initial turn in while sacrificing on the mid to exit steering. The one other benefit in disguise is that it doesn't scape the track no matter how low you set the ride height. The springs are very soft initially but get stiffer and then fully compress before the chassis touches the ground so you get a lot of usable dampening while never really worrying about ride height. I don't know if this applies that much to rcp users though because the ride height thing mainly helps with the foam tires because it means that you can true tires to a smaller diameter (always makes it faster and better handling) without worrying about losing corner speed due to rubbing. Feeling the front end in my hands it is very smooth when used with the bottom swing arm set and if used with the bottom swing arm set ride height and preload become much easier to adjust compared to a dbl aarm. With all that there are also a couple of racers that I know that have tried it and gone back to the pn dbl aarm because they felt that in the turns the dbl aarm was smoother and was better.
Old 2015.01.04, 05:19 AM   #4
byebye
byebye's Avatar
Thanks for the reply dmalmad.
Old 2015.01.09, 08:06 AM   #5
TheRinger
THATS HOW I ROLL
TheRinger's Avatar
Thanks for the info guys. I'm looking around for a new front end since reflex racing no longer makes theirs and I don't feel like dropping a small fortune in a PN front end for my brushless chassis.
Old 2015.01.09, 12:36 PM   #6
i have an extra RR front end for you, if you want it.
Old 2015.01.09, 05:32 PM   #7
As do I. Including the set up tool.
PN Double A-Arm Front Suspension benmlee PN Racing 374 2016.03.08 02:34 PM
Front end chatter Tapir Setups 10 2011.10.27 08:43 AM
R246 MR-03 Front End Suspension Set arch2b New Products 14 2011.02.20 03:43 AM
Vital Statistics arch2b Autoscales, Bodies, Cars and Drivers 40 2007.08.14 09:30 AM
Adjustable Width Front Chassis DAMZer Chassis 30 2002.07.21 03:15 PM
