Old 2015.01.12, 08:52 PM   #1
New Kyosho Mini-Z Products 2015
No. ORI32408
TEAM ORION PRO-AM Digital Charger (EZ CHARGER SERIES)
with 800HV AAA Batteries (4pcs)
ETA: February 25, 2015
Input Voltage: AC100 to 240V, DC 12V Charge Amp: AA DC 1.4V 2200mA, AAA DC1.4V 800mA Charge cell type: AA and AAA Ni-Mh and Ni-Cd Cells: 1-4 cells (independently controlled) Charge time: 70 minute (AA 2100mAh, AAA750mAh) Delta Peak: Yes Refresh: Yes Zero Voltage jump start:Yes Trickle Charge: Yes Protection: Reverse priority, Over charge and Short circuit protections Display: Blue LED Include: 4 Orion 800HV AAA Ni-Mh batteries
No. ORI30404
Old 2015.04.26, 08:28 AM   #2
these lok very interesting! for once, we look to be getting a good intro level upgrade kit with the essentials; bearings, tires and debatable springs.
No.MZW2015MM
MR-03 circuit pack
(MM / rear tires: Wide)
3,500Tasu tax
release May 2015
No.MZW2015RM
MR-03 circuit pack
(RM / rear tires: Wide)
3,500Tasu tax
release May 2015
Old 2015.04.26, 08:44 AM   #3
Kyosho Syncro EX-6 Mini-Z radio system
Kyosho America have announced first details on their all-new Syncro EX-6 Mini-Z radio system. The newest and most advanced radio ever built for use with the Mini-Z cars from Kyosho is based on the EX-2 radio system just introduced by KO Propo. It takes advantage of the “KIY” (Kustomize It Yourself) system that allows modular expansion and modification of the radio system, and it has a new ultra-fast hybrid mode that is faster than any system currently available. The Syncro EX-6 features a high level of adjustability via precision digital settings that remain stored in the radio’s memory. Most of the settings are adjusted via the two-position LCD display, which can display data in line with the radio for more conventional viewing, or it can be rotated to a transverse position, which makes it easier to view settings and data from the side of the radio.
Apart from its wide range of settings, the precise control it offers, and the legendary quality of KO Propo electronics as a calling card, the EX-6 also has a newly developed protocol called “MHS” (Mini-Z Hybrid Spread Spectrum System) that has a response time that’s four times faster than the ASF systems currently used by other high-end mini-Z chassis. The only car that currently is compatible with the MHS protocol is the Mini-Z Racer Pro MR-03 VE being released at the same time as the radio. The EX-6 is also with cars using the ASF protocol, so of it will be compatible with any of the previous model high-performance Mini-Z models (not Sports models). One additional advantage with the MHS protocol is it allows the transmitter to bind with the receiver very quickly. ASF systems take a little longer to bind in an environment where there’s a lot of radio traffic. The MHS system binds quickly regardless of the conditions.
The EX-6 uses KO Propo’s patented K.I.Y. system, which means this radio is compatible with a number of accessories, but you can also get an optional FHSS master unit and a receiver to operate other RC cars in your fleet in addition to the Mini-Z. A number of grips, battery holders, drop-wheel adapters and other accessories are already available. The radio will become available in July.
Features
– Four times faster response than KO’s EX-I when used with MR-03 PRO
– Also compatible with ASF systems
– Large backlit LCD panel that displays both English and Japanese menus
– 10 model memory
– Manual counting of lap times up to 100 laps
– Compatible with Chase Mode
– Steering Auto Balance – Quick and easy set-up of steering travel in both directions
– Permits gyro adjustment without using ICS or similar programmer
Old 2015.06.09, 07:37 PM   #4
New Mini Z June Arrivals
32126WR-B MINI-Z AWD Sports SUBARU IMPREZA WRC 2002 Ready Set
MZP143WR-B ASC MR-03N-RM SUBARU IMPREZA WRC 2002
32163CW-B MINI-Z AWD MA-020VE BCS SAVANNA RX-7 RC3S Aero CFRP White +D Evo.
MZP421CW-B ASC MA-020 SAVANNA RX-7 RC3S Aero CFRP White
32232R-B MINI-Z Racer MR-03S Shelby Cobra Daytona Coupe Red Ready Set
MZP144R-B ASC MR-03N-RM Shelby Cobra Daytona Coupe Red
32204GSL-B MINI-Z MR-03S2 Audi R8 LMS Phoenix Racing NBR 2010 #99
32741B MINI-Z MR-03VE Chassis / Tx Set
MZW431 Gyro Unit Set(for MA-020S)
Old 2015.06.10, 01:40 PM   #5
Pierro
Hey Arch!
Where did you found out this news? I can't get any information on my usual sources and found nothing on the kyosho website.
This body was listed on the french importer website though, but my local shop did not get any news from the importer when he asked about it.
Pierro is offline   Reply With Quote
Old 2015.06.10, 03:23 PM   #6
the shop here receives product notices from thier kyosho rep, which is reviewed for redistributable information which is then provided and i post.
i was SHOCKED to see the daytona get a re-release! i've been looking for an affordable copy for track use for ages.
Old 2015.07.06, 01:03 PM   #7
New Mini Z Arrivals For July
No. 82030B Syncro EX-6 (Mini Z Compatible)*Non Sports Mini Z Only!
No.82136B Syncro Touch KT-432PT Transmitter (All Standard Land RC Cars + All Sports Mini Z) (MR-03S + MA-020S + Overland Sports)
No. 32741B Mini Z MR-03VE Chassis + TX Set
No.32126WR-B Mini Z AWD Sports Subaru Impreza WRC 2002
No.32127W-B Mini Z AWD Sports MA-020S Ready Set
No.32128W-B Mini Z AWD Sports MA-020S Ready Set Mazda Savanna
No. 32130BK-B Mini Z AWD Sports MA-020S Ready Set Nissan Skyline GT-R R32 RX-7 FC3S
No.MZP143WR-B ASC (Body Only) MR-03N-RM
No. MZP421CW-B ASC (Body Only) Savanna RX-7 RC3S
No.MZP423W-B ASC (Body Only) Toyota Sprinter Trueno AE86 Initial D
No.MZP424W-B ASC (Body Only) MA-020 Mazda Savanna RX-7
No.MZP426BK-B ASC (Body Only) Nissan Skyline GT-R R32 V.spec II
Old 2015.07.30, 03:05 PM   #8
Just Arrived! (available for retailer order)
No.32128W-B Mini Z AWD Sports MA-020S Ready Set Mazda Savanna RX-7 FC3S
Old 2015.08.01, 01:58 PM   #9
WorldClassZ
Still no brushless Buggy.
MR01AM, MR015AM (X2), MR02iAM, MR02AM, MR02ASF, MR02LMASF, MR03ASF (x3), MA010ASF, MB-010ASF, MV-01ASF, MM-01ASF
WorldClassZ is offline   Reply With Quote
Old 2015.08.01, 03:00 PM   #10
there in asia shops already so just making there way west...
Old 2015.09.08, 03:34 AM   #11
Petrokl
New stuff:
New MA-20VE Pro:
Source: RC.P.Sanda
Petrokl is offline   Reply With Quote
shop.tinyrc.com (Corrected): 10% off ALL MB-010 Products, 40% off Mini Inferno Bodies Mrs Mini-Z Newsletters 1 2012.04.20 09:36 AM
shop.tinyrc.com (Corrected): 10% off ALL MB-010 Products, 40% off Mini Inferno Bodies Mrs Mini-Z Mini-ZRacer.com Announcements 0 2012.04.09 12:14 PM
24 Hours of Le Mans = 24% off AutoScales!!! Mrs Mini-Z Promotions 1 2010.06.12 11:19 AM
Gil Losi, Jr. Moves To Kyosho America arch2b Mini-ZRacer.com Announcements 0 2007.03.21 04:22 PM
other new kyosho products... herman Parts and Hop-ups 6 2003.05.22 08:11 PM
