Old 2015.01.22, 06:56 PM   #1
Solo1
Old nut
Talking 70t motor in a s
Can someone tell me why the 70t motor will work in an 03s but not have reverse?
Solo1 is offline   Reply With Quote
Old 2015.01.22, 07:15 PM   #2
Sounds like a trim issue.
Old 2015.01.22, 07:36 PM   #3
Solo1
Old nut
trim? Keenon says its not compatible with the s but i thought it would be because of the motor mount which i bought too so i thought it would work (which it does rather well) except for no brake or reverse, if you hit it twice fast enough it will run forward with the trigger pushed all the way forward?
Old 2015.01.22, 08:11 PM   #4
The most likely reason for the non compatibility disclaimer would be to avoid any responsibility for potential damage to your electronics if you do something stupid and try to blame them. What you are experiencing sounds like a transmitter reset could resolve.
Old 2015.01.23, 09:35 AM   #5
Kevinmueller
Bavarian Bullet
Like the others said it could be a transmitter setting issue but if you can't get it fixed that way then you could have also burnt out the FET's for reverse (they are separate for forward). This would still allow you to have forward power but no stopping or reverse power. My suggestion would be to switch back to the stock motor to check if it still has reverse if it does you have a transmitter issue. If it doesn't have reverse you probably need new reverse FET's.
Kevinmueller is offline   Reply With Quote
Old 2015.01.23, 06:46 PM   #6
Solo1
Old nut
[IMG][/IMG]
so this is what i found. if i replace these with 8858 i'm guessing that would be the best cure?
Or should i get the 1's from pn?
Old 2015.01.23, 07:29 PM   #7
I would call that a fried fet. Some of the older PN motors had a fairly substantial eyelet on the motor leads. If either came in contact with a fet leg it might have been the issue. Hence the PN disclaimer. And 8858's all the way.
Since I have never been into a sports series board what is that substance that looks like "duck butter" all over the corner of the board?
Old 2015.01.23, 07:45 PM   #8
Solo1
Old nut
no idea! should i go 2 8858 or 4?
Old 2015.01.23, 08:41 PM   #9
If your soldering skills and equiptment are up to it I would say go for it. Bear in mind though if you decide to go above a 70T motor you will have your hands full.
Old 2015.01.23, 08:44 PM   #10
Solo1
Old nut
dont know if my skills are that good but i've been running a xspeed motor too and know what you are saying.
Old 2015.01.24, 06:58 AM   #11
Worst that can happen is you ruin the board. If that happens just spend the extra money for a ASF 410 board and your problems are over since any of the conventional 2.4 radios will work.
Old 2015.01.27, 08:12 AM   #12
Jshwaa
Jshwaa's Avatar
Contrary to popular belief, there really isn't a 'reverse' FET and a 'forward' FET. They are both used in forward AND reverse, however a FET can fail leaving either forward or reverse STILL working.
Old 2015.02.03, 10:10 PM   #13
Solo1
Old nut
Well just as a update to this i just finished replacing the fets in my car, what a project! smallest things i ever soldered but it works!! Read all sorts of things about getting them off found the simplest way to get them off was a pair of dykes!
Old 2016.02.15, 09:15 AM   #14
WKDK95
does the stock MA-020s support the PN 50T motor?
WKDK95 is offline   Reply With Quote
Come on down for some Good Old 70T stock come!back! machgo5go Mini Z Racing, Maj's Hobby Shop, Saddle Brook NJ 26 2011.11.03 11:20 PM
X-speed V vs. CTP 70t thestug Mini-Z AWD MA-010, MA-015 5 2011.05.03 05:16 PM
PN 70t HFAY motor wont fit in my MA-010 ScoobyPete Motor Tech 1 2010.03.01 08:22 AM
PN Racing 70T Motor Gearing? sell682 Motor Tech 20 2009.08.07 12:01 PM
Anyone tried PN 70T in AWD ProfoxCG Mini-Z AWD MA-010, MA-015 56 2009.03.05 12:34 PM
