Old 2015.07.04, 01:13 AM   #1
mini-cam
PDXminiz.com
mini-cam's Avatar
Speech does not work
I can not get the Speech option to work. Is this not a working feature with Windows 7? Tried another PC and get the same error. When checking the speech box I get "Error Preparando WAV Para Posiciones : Floating point division by zero"
None of voice files play only the sound files.
Is there a fix or a patch for this to work? Other than speech the software works great!
mini-cam is offline   Reply With Quote
Old 2015.07.05, 01:49 PM   #2
zround
That is a warning. There was not possible to generate cache files but it shouldn't let unusable the voice system.
Once the voice is selected, can you test it? (enter a text and click on "listen" button). Or nothing works?
Old 2015.07.05, 07:04 PM   #3
mini-cam
PDXminiz.com
mini-cam's Avatar
Nothing I type in the box can be heard. All the sounds work during the race. Just not the voice prompts. On the champion manager I can type words in that box and hear speech fine. Just not the scoring screen.
Old 2015.07.08, 04:21 PM   #4
zround
OK. Let me make some tests.
I'd like to reproduce your environment. Have you installed the software under "program files" or it is a custom folder?
Has your windows user "administration" privileges?
Old 2015.07.08, 05:03 PM   #5
mini-cam
PDXminiz.com
mini-cam's Avatar
Thanks
Thanks for your help. On the laptop we use for the club it is saved in the documents folder. I might have a problem with my Norton Virus software. Last night I ran some practice races and noticed now some of the sound wave files have been removed and the track builder software was killed. Tonight I will try and remove the software, reinstall, and make sure Norton accepts all of the software.
Really exited for our club to try and use the software for our races. We want the have a points series race soon and this software looks like it will make is real easy to do.
Old 2015.07.26, 01:00 PM   #6
zround
Thank you for the feedback. Enjoy ZRound!
Old 2015.11.04, 09:58 PM   #7
Thorvald
Thorvald's Avatar
Interesting, I just installed ZRound to try it tonight with my Trackmate setup and same issue here with Windows 7. I get the error you do and no speech.
However Flipside and the default Trackmate software work fine with speech.
The test button does not say anything when pressed (Microsoft Anna selected and some text entered into the text box).
Old 2015.11.04, 10:24 PM   #8
Thorvald
Thorvald's Avatar
Just an update to this, used "narrator" to verify speech api is working fine.
The error message occurs when we enable SAPI, as soon as we uncheck and then check the box for SAPI 5.1, I get the error:
Para Posiciones is "To Position" or "For Position" is it not?
Any ideas?
Thanks
Tim
P.S. latest version, just downloaded tonight.
Old 2015.11.30, 05:49 PM   #9
Thorvald
Thorvald's Avatar
I was able to fix mine through a re-install and just left the voice section "blank". It just worked fine.
Old 2015.11.30, 06:23 PM   #10
zround
Hi, I've received the same issue on my mail. I will receive soon (I hope) a debug trace file to see what could happen.
I used Win7 (8, 8.1 and now 10) with voices and it always worked.
I'll keep you informed. Regards.
Old 2015.11.30, 08:15 PM   #11
Thorvald
Thorvald's Avatar
Sounds good, if you need any more debug info just ask.
My setup will re-produce the reported error as soon as I manually select a voice.
Cheers
Tim
Old 2015.12.07, 11:22 AM   #12
zround
Cheers
Tim
I've been working on the SAPI interface and it seems the issue has been solved. Unfortunatelly I don't know what causes the issue and I've not been able to reproduce it in any of my environments.
Please contact to me by mail in order to send you a special build for testing.
Best regards,
Jesus.
Tags
zround speech
Speech translations pinwc4 Flip Side 0 2010.01.05 07:30 PM
can a 3pk module work with a Ko Propo EX-I UR? SPANKY Transmitters, Receivers and Crystals 0 2009.08.30 08:10 AM
Kyosho motor spacers do not work w aftermarket motors? ProfoxCG Mini-Z AWD MA-010, MA-015 5 2008.12.04 10:22 PM
Will the atomic z2 motor work with a spy esc? minittrackmann Motor Tech 2 2007.06.23 02:42 PM
my car doesnt work jrmini Beginner Questions 1 2001.12.31 03:07 PM
