Old 2015.10.30, 09:10 PM   #1
ilove599xx
How to avoid Car Flipping?
Hi,
recently I've been driving with Lamborghini Murcielago LP670 MR03W-MM body. My car always flips on the first time after straight line. I don't think I had this problems with other car bodies.
My club owner said I could make the upper body lighter. Such as take the front light off, etc.
What do you guys think?
Do you think this is a good body for training for me since this is the only body will flip from my car collection. So If I can drive this one without flipping on every turn, I will be ok with other bodies?
Old 2015.10.31, 06:10 AM   #2
Since the Lambo is famous for this behavior you might try a couple of different things. First, check to see if the inside front wheel(while turning) is coming in contact with the lower edge of the windshield. Secondly, try reducing the front wheel off-set by .5 to 1mm to give additional clearance while turning.
Old 2015.10.31, 07:24 AM   #3
If your looking for a training body, pick something squared off and has all the rail grabbers up front . That will teach you the best lesson, staying off the rails!
As mike suggested, make sure the tires are not rubbing the inside of the body. The rest is suspension setup particular to that body and your track.
Old 2015.10.31, 12:04 PM   #4
ilove599xx
my wheel set are orginal, will that will rub inside of the body?
I will check it out,
for this moment, I don't have offset 1 wheel, so if I want to change the front spring to make this problem less, should I make the spring harder?
thank u all
Old 2015.10.31, 12:15 PM   #5
ilove599xx
so which bodies would have something squared off and has all the rail grabbers up front
Old 2015.10.31, 03:54 PM   #6
Honda HSV, Audi R-8, Aston Martin, New Lexus, Old style Lexus(94mm) just to name a few.
Reflex inspired set up hrdrvr Reflex Racing 40 2009.12.13 02:36 PM
Can you pair more than one car...? Mead 2.4GHz ASF System (Auto Selected Frequency) 6 2009.09.17 09:51 PM
FS: RTR Kyosho 1/10th rally car, Airtronics MXA ChattavegasSE Mini-Z Marketplace 9 2008.05.29 10:33 PM
'Neutral car' and newbie learning Aurora Mini-Z AWD MA-010, MA-015 5 2007.02.18 07:54 PM
Traction Flipping 01 docsavage Setups 10 2005.02.12 09:46 PM
