Old 2016.01.29, 06:32 PM   #1
Gixer1K
Gixer1K's Avatar
Motor Screw Size
What size are the motor screws that PN uses?
I want to add motor screw holes to my stock VE motor so I can put it in a PN motor mount.
Thanks
Bob
Gixer1K is offline   Reply With Quote
Old 2016.01.29, 10:04 PM   #2
byebye
byebye's Avatar
2mm machine threads. M2
Old 2016.01.30, 06:48 AM   #3
briankstan
SLMZ / HFAY
briankstan's Avatar
Thanks
it can be done, but be careful so you don't ruin the motor. by hitting the comm inside when your drilling.
Old 2016.01.30, 06:59 AM   #4
You will certainly want to utilize a "bottoming" tap for final threading. This will reduce the risk of interference with the windings. But only by a little. It can be extremely touchy if you haven't had some experience with this kind of operation.
Old 2016.01.30, 11:57 AM   #5
Gixer1K
Gixer1K's Avatar
Can the VE motor be disassembled?
Bob
Old 2016.01.30, 12:44 PM   #6
I know that the Orion/Kyosho motors can be disassembled quite easily. You just need to be very careful as I would expect you would be. The trick is laying out a pattern for drilling holes all around the end bell so you can properly clock the motor to the mount. DuBro as well as some other companies make a matching drill bit and tap but you will still need access to a good bottoming tap to properly complete the process.
Old 2016.01.30, 01:49 PM   #7
Gixer1K
Gixer1K's Avatar
Found a bottoming tap on Amazon, so that's on the way.
Thanks for the help ya'll.
Bob
Need an OFF Bearing Size (for MiX) Draconious Miscellaneous Discussion 3 2007.11.11 03:28 AM
Screw size for mini z Dustin Parts and Hop-ups 2 2005.03.11 04:48 PM
hopping up 130 size motors!!!!! mini Z modifier Motor Tech 17 2002.11.01 04:43 PM
Z130-M-BB Pinion size and meshing. butler Motor Tech 9 2002.09.29 03:39 PM
Track size ty_r_k Tracks and GTGs 20 2002.08.19 03:39 PM
