Old 2016.02.06, 10:43 PM   #1
Sinister_Y
Sinister_Y's Avatar
MC3 Wide Front-End Stability Kit
Available now- MC3 Wide Front-End Stability Kit:
This is a high strength 3D printed kit. The material is nylon and printed using SLS technology, meaning high precision. It's akin to commercial plastic injection molded parts.
This part is only compatible with a MR-03 compatible chassis using the newest PN Double A-Arm Front suspension system for MR03 (parts number MR3070 or MR3062).
This kit lengthens both the upper and lower arm lengths from the stock PN lengths by 2mm on each side. This allows you to run zero offset rims for many popular racing bodies, which normally would have required a 2mm offset front rim.
Why this is important is that this gives you consistent handling and precise steering. This is due to the fact that there is reduced play in the fit of the components and it takes away the MR-03's variable camber effect which can lead to handling issues like flipping after straightaways into turns, inconsistent steering feedback, etc... as there is too much camber gain while cornering.
Kit comes with:
2 long upper arms with sway bar mount
2 long lower arms
6 long MR-03 toe-bars:
1 toe-out bar
1 zero toe bar
4 toe-in bars
Install Tips below:
https://youtu.be/_7BjCPpMEvI
Note, we offer wholesale pricing to qualified dealers.
Mini-Car Club of Canada (MC3)
www minicarclubofcanada com
Last edited by Sinister_Y; 2016.02.08 at 01:09 PM. Reason: forum can't do embedded you tube video
Old 2016.02.07, 10:29 AM   #2
byebye
byebye's Avatar
Good stuff! Do you have any installed pics?
Old 2016.02.07, 03:03 PM   #3
Sinister_Y
Sinister_Y's Avatar
Thanks. I'll add some soon. I may offer colours soon. The tip video is yellow and I also printed black, which looked good.
Old 2016.02.07, 03:24 PM   #4
lfisminiz
lfisminiz's Avatar
Looks good like the rest of your products.
Old 2016.02.20, 01:52 PM   #5
Kevinmueller
Bavarian Bullet
Here are some pictures of the wide front end stability kit installed on my MR03.
Kevinmueller is offline   Reply With Quote
Old 2016.02.20, 01:53 PM   #6
Kevinmueller
Bavarian Bullet
I can only load one photo at a time from my phone
Old 2016.02.20, 01:54 PM   #7
Kevinmueller
Bavarian Bullet
And the last one
Old 2016.02.20, 06:58 PM   #8
lfisminiz
lfisminiz's Avatar
Thanks for pics.
Old 2016.03.20, 08:34 PM   #9
lfisminiz
lfisminiz's Avatar
So far looks like another real good product.
Old 2016.03.22, 07:00 PM   #10
Mike Keely
Hi Kevin, I had a question. It looks like you have a washer under the top bar that the upper A arm attaches to? Are you having a traction rolling issue? Thanks
DG-Designs / Brooklyn Hobbies
Old 2016.03.27, 12:07 AM   #11
refsiul22
refsiul22's Avatar
Questions
Interesting product, congrats... It is a shame that all 3D printed upgrades are being banned for competition (e.g. PNWC2016 rules)
Had a few questions:
Does it work with PNR2.5W chassis?
Does the sway bar have an important effect at this scale? Does the kit include the bars?
Is it possible to configure a -1 offset and how?
Where can I get this stuff?
Old 2016.03.27, 07:57 PM   #12
Sinister_Y
Sinister_Y's Avatar
Hi
My understanding is that 3d printed parts are OK for open pan car class but nothing else.
Yes, but as noted you need the newer PN double a-arm kit which fits pn 2.5 chassis
For our testing/ racing yes. The real benefit is the extra width. We decided to add an option of being able to use sway bar which 2 bars come with the kit.
Sure but it depends what body you are running if that is appropriate or not. For most bodies that racers use, thr 2mm wider arms allow to use zero offset rim whereas before it would be 2mm offset rim.
Check my signature.
Old 2016.03.27, 11:35 PM   #13
refsiul22
refsiul22's Avatar
Originally Posted by Sinister_Y View Post
Hi
Check my signature.
Thanks for the quick response Sinister. Want to try it for sure.
I run 90% of the time +2 front offset. For the last weeks I have been trying a 599XX with +1 front offset... With good results.
Just checked your site, prices are CADs?
Old 2016.03.30, 01:24 AM   #14
Sinister_Y
Sinister_Y's Avatar
Hi
Yup, all prices are in Canadian dollars.
I used to run 599xx all the time but found the McLaren 12c to give more steering and balanced rear end grip so switched to that body for now.
We also all switched to marka 10 deg V1 rears as well and can use the PN KS medium front tire or the Marka V6 25 deg fronts.
Old 2016.03.30, 10:31 AM   #15
refsiul22
refsiul22's Avatar
Hi
Thanks Sinister
And yeah, I have the 12C in my upcoming projects..
Definitely, I have tested that same combination. But for me, Marka 15 deg tires are comparable to PN medium. I couldn't even drive with 25 deg (but I guess that's for another thread)
MR03 Double A-Arm Wide Front Conversion Kit Ancient Artist PN Racing 3 2015.12.29 12:38 AM
WTB- Reflex Racing Wide Front End Kit Mini-Z#12 Mini-Z Marketplace 0 2009.08.03 06:19 PM
gpm front lowering kit West.F1 Parts and Hop-ups 0 2002.09.20 11:17 AM
Going wide in tha front Slonik Setups 4 2002.09.10 06:13 AM
my rookie review: front end springs West.F1 Mini-Z F1 MF-010, MF-015 12 2002.06.30 11:08 PM
