Old 2016.03.31, 06:22 PM   #16
Kevinmueller
Bavarian Bullet
Originally Posted by Mike Keely View Post
Hi Kevin, I had a question. It looks like you have a washer under the top bar that the upper A arm attaches to? Are you having a traction rolling issue? Thanks
Hi Mike, that's a good eye you have their. The washers are their to bring the bar back up to the stock height. I was experimenting with different roll centres on the old PN double A arm system and had milled down the top plastic cover to get more adjustment range. The new system,which you see on my car, does not have separate upper and lower towers like the old system, therefore the upper and lower arms are a fixed distance away from each other and the roll centre can no longer be changed. So I simply returned the upper tower to the original height using the washers.
Kevinmueller is offline   Reply With Quote
MR03 Double A-Arm Wide Front Conversion Kit Ancient Artist PN Racing 3 2015.12.29 12:38 AM
WTB- Reflex Racing Wide Front End Kit Mini-Z#12 Mini-Z Marketplace 0 2009.08.03 06:19 PM
gpm front lowering kit West.F1 Parts and Hop-ups 0 2002.09.20 11:17 AM
Going wide in tha front Slonik Setups 4 2002.09.10 06:13 AM
my rookie review: front end springs West.F1 Mini-Z F1 MF-010, MF-015 12 2002.06.30 11:08 PM
