Old 2016.02.17, 09:33 PM   #1
byebye
byebye's Avatar
Open Wheel Kit
I've developed an open wheel kit designed for the MR-03 that uses screw holes found on the rear end of the PN alloy motor mount.
I designed this so that you could run your racer open wheel but still have protection on the front end. I used the XYZ DaVinci 1.0 3d printer and Simplify 3d to slice the 3d model. I used TinkerCAD to draw up the design and save it as an .STL file for printing.
The chassis is a 98mm PN2.5 with A-Arm kit. I'm running zero offset Wide wheels up front and +3 offset Wide wheels in the rear. The esc and motor are Kyosho Mini-Z VE board and Atomic VSX 5000kv. All the holes were drawn into the model but the printing is not precise enough to leave a perfect hole so I use couple small drill bits to open them up.
The kit is four pieces all screwed together-
Attach the box to the motor mount-
Old 2016.02.17, 09:33 PM   #2
byebye
byebye's Avatar
Attached the rear diffuser-
Now the wing. I sanded the bottom of the base of the wing just to get a flatter more consistent surface-
Old 2016.02.17, 09:33 PM   #3
byebye
byebye's Avatar
Now attach the front wing. This is pretty cut and dry. It uses the existing screw holes for the nose clip-
In total I've spent ~15 hours printing and designing to get what you see. I need to give the front nose clip one more redesign. It's very thin at front edge. Earlier versions of the wing were larger which I may end up going back to.
Here are a few other things I made-
Old 2016.02.18, 12:18 PM   #4
i look forward to it's continued evolution
Old 2016.04.06, 08:40 PM   #5
Haven't been on the forums much lately... Just saw this, have to say it looks really good!
Route 241 Raceway at Kyosho Tim Johnson Route 241 Raceway, Lake Forest CA 399 2015.01.13 02:49 PM
Racing rules at Cruizin' with RC's GIHOSU Cruizin with RC's, Waldwick NJ 13 2012.01.19 10:05 PM
Wheel enforcements... HaCo PN Racing 4 2009.08.12 12:15 PM
KT-18 Steering Wheel Swap! ruf 2.4GHz ASF System (Auto Selected Frequency) 10 2008.03.04 01:07 PM
Custom Open Wheel Bodies crusader4x Mini-Z F1 MF-010, MF-015 9 2002.03.21 07:54 AM
