Old 2016.09.07, 03:03 PM   #31
TeeSquared
Redline
The biggest difference it made was that the rear end tends to chatter a lot more now, especially under power in a turn. Lap times are very good in the 94 mm configuration but the car does not handle as well at it did in the old, 98 mm setup with the disk damper and shock.
Old 2016.09.17, 11:59 AM   #32
MR-03VE PRO GP Limited Chassis Set
As usual, checking the JPN site shows some interesting stuff coming down the road. I don't recall seeing any previous reports on this chassis st but it looks very nicely equipped 8)
No.32880
Release Date December 2016
Minute best ever spec Xspeed VE PRO brushless motor given
produce a different dimension of performance that does not live up to the naming of the "GP"
16 times for a combination of a conventional ASF2.4GHz system + KT-18 transmitter, adopted MHS2.4GHz system which boasts an ultra-high response of four times the combination of ASF2.4GHz system + KO PROPO made EX-1 transmitter as the third installment of the MR-03VE PRO series, it appeared "GP Limited". The maximum of the topics of this machine can be found in the adoption of Xspeed VE PRO brushless motor to be a new development. Xspeed VE PRO brushless motor eye-catching when aluminum case is a person that was an integral heat sink indispensable for cooling high-spec is given that the KV value 12000, realizing the high-speed travel that does not look at the Minute history class. In addition, the traveling, such as ball def set that enables low center of gravity and greater heat dissipation promotion contribute to MML aluminum motor mount, MML roll damper that more can be brought close to the setting of their liking by adjusting width is spread, the cornering no stall standard equipment optional parts to enhance performance. Moreover, these optional parts, both are only color anodized, which was adopted in the decorated GP Limited, a special sense of perfect score! In the past to being able to experience the different dimension of driving it did not have to taste, of course, that there is no doubt to be one that will be filled to the possessiveness.
Xspeed VE PRO brushless motor (KV12000) MR-03 chassis set that was first adopted in the new development.
Standard equipment MML aluminum motor mount and MML roll damper employing a hard anodized aluminum.
Always motor terminal and battery terminal gold-plated specification boasts a good power supply efficiency.
Boasting a Minute fastest response adopted "MHS2.4GHz system".
ICS system is available manager for traditional VE is.
Full bearing, ball differential (black anodized).
MR-03 chassis-related optional parts can be installed.
Ingenious front suspension to change the camber in accordance with the stroke "VCS".
ASF2.4GHz also corresponds to the system. ※ transmitter are sold separately.
Equipped with a digital steering servo coreless motor adoption.
Easy coil spring replacement of the front suspension is a spring stopper that can be desorbed with two screws.
<Kit contents>
Team ORION Xspeed VE PRO brushless motor equipped with MR-03W-MML factory assembled chassis
Pinion gear (6T, 7T, 8T, 9T)
Wheel wrench
Pinion disassembly tool
Spare wheel nut
<Required for operation>
ASF2.4GHz transmitter KT-18 or MHS2.4GHz transmitter EX-6
※ To use the Mini-Z HYBRID SPREAD SYSTEM (MHS) is a must have the corresponding transmitter.
Auto Scale Collection (body set, wheel, tire)
Traveling for AAA four alkaline or nickel-metal hydride battery
AAA batteries 4 for transmitter
Old 2016.09.17, 07:45 PM   #33
lfisminiz
lfisminiz's Avatar
Does look pretty good.
Old 2016.09.29, 12:37 PM   #34
TeeSquared
Redline
Sexy! I plan to buy one
Old 2016.09.29, 09:47 PM   #35
Nsxtat
I wonder if you can run a 94mm body with that setup.
Nsxtat is offline   Reply With Quote
Old 2016.09.30, 02:44 AM   #36
TeeSquared
Redline
Thinking about it a little more though, 12K KV is crazy and will probably be quite a handful on small-medium club RCP layouts. I'll bet many of us will find ourselves turning the throttle way down to improve the driveability, but Kyosho has surprised me in the past with how well limited edition cars are dialed out of the box so who knows Sure looks cool though:
Old 2016.10.01, 04:03 PM   #37
TheSteve
VE7FM
I want one - but a special color chassis should have been part of the kit.
Old 2016.10.03, 12:28 PM   #38
no drilled motor can... this is perhaps the biggest disappointment of them all with kyosho motors. They fancy themselves a 'premiere' brand thus closed system it seems. it really is to their detriment.
Old 2016.11.20, 08:32 PM   #39
TeeSquared
Redline
https://www.kyosho.com/eng/products/...duct_id=111608
MA-020 VE SP. Been a while since we've seen an SP AWD chassis It's too bad it doesn't come in a special color though.
Old 2016.11.20, 09:16 PM   #40
TheSteve
VE7FM
Should have been done in all red.
Old 2016.11.21, 06:31 AM   #41
i agree. it would have made it more special or unique if in a new color vs. just a hopped up version.
also, why not include the same VE pro motor the MR-03 limited chassis gets?
Old 2016.11.21, 06:51 AM   #42
Evil_Sephiroth
I have the MA-020VE PRO.
Atm it's very fun to drive...and except the included gyro..not really much difference with this SP.
Evil_Sephiroth is offline   Reply With Quote
Old 2016.11.21, 01:23 PM   #43
TeeSquared
Redline
Heat, and probably because the stock drivetrain could never handle it. The diffs will shred, the pinions will melt onto the motor shaft, and the driveshafts will twist into pretzels. I'd think at minimum you'd need either the hard gear diffs or ball diffs and the alloy driveshafts to handle that kind of horsepower, but it would be friggin epic and probably extremely competitive when set up properly. The MA-020 is a very fast car and is more competitive than 2WD on technical tracks IMO.
Wonder why they don't just include the buggy hardened diffs on the VE AWD chassis by default, and the alloy driveshafts on the SP cars as another added bonus. I guess its all to keep the price down but Kyosho has slacked off on content on their special edition cars and it's lame. Even their latest special color chassis (the blue JSCC chassis) only came with a ball diff and bearings. Back in the day, you'd get the diff and bearings but also kingpins, shims, springs, oil shock, t plates, damper plate and wheel nuts. The cars were dialed out of the box!
Old 2016.11.21, 01:49 PM   #44
description
Loaded with the dynamic combination of MHS (MINI-Z Hybrid Spread Spectrum) and Xspeed VE brushless motor, the MA-020VE PRO released in November 2015 relaunches as an SP chassis set including the previously optional motor cooling system to be the fastest MINI-Z in history. Loaded with the same lightning fast 8500KV Xspeed VE brushless motor power source as the MA-020VE PRO, the SP Chassis Set is also equipped with an aluminum motor sleeve and motor cover to control heat and extract every drop of power from the brushless motor. The motor sleeve and motor cover are anodized in the premium "SP" color, while the normally grey main chassis is anodized in intimidating black. Also, in what has become a must-have racing item, the SP chassis set includes a gyro unit set as standard. Packed with high-performance optional parts, the MA-020VE PRO SP Chassis Set is a base chassis built ready for racing battle. As with the MA-020VE PRO, the SP Chassis Set is compatible with existing ASF2.4GHz systems. As transmitter setting is automatically done when pairing, KT-18 and KO PROPO EX-1 transmitters can also be used.
noted to include:
MA-020VE PRO features brushless motor with previously optional cooling system.
SP chassis specifications are identifiable with the special red anodized motor sleeve and hard anodized motor cover.
Main chassis is finished in formidable black.
Includes optional gyro unit set as standard.
Nickel plated hex screws are used on all main sections.
Features the MHS2.4GHz system with the fastest response speed in MINI-Z history.
Compatible with ASF2.4GHz systems. *Transmitter is sold separately.
Incorporates the "VCS" front suspension from the MR-03.
Double wishbone suspension (DWS) equipped on rear.
Full ball bearing specifications include a total of 14 precision ball bearings.
Equipped with wide rear suspension arms.
no mention of a differential upgrade
Old 2016.11.21, 04:58 PM   #45
TeeSquared
Redline
description
It might be okay with the 8500 KV brushless if you don't hit the wall too often, but I suspect this car will be a little fragile until the diffs and driveshafts are upgraded.
Kyosho Mini-Z R/C Units arch2b Parts and Hop-ups 10 2017.10.30 12:30 PM
September 24, 2016 - Kyosho Stock - Special Event arch2b Washington DC Area GTG, MD/VA/DC 6 2016.10.03 06:19 AM
shop.tinyrc.com (Corrected): 10% off ALL MB-010 Products, 40% off Mini Inferno Bodies Mrs Mini-Z Newsletters 1 2012.04.20 09:36 AM
shop.tinyrc.com (Corrected): 10% off ALL MB-010 Products, 40% off Mini Inferno Bodies Mrs Mini-Z Mini-ZRacer.com Announcements 0 2012.04.09 12:14 PM
