Old 2016.10.06, 01:04 AM   #1
jcstuezday
†hazel 5'7" mayan owl†
jcstuezday's Avatar
Wink i made a 1:18 scale MA-010
i do not have it real nor do i have it draw up in photoshop
but it iz realy e z to explain
what it haz az option
adjustable
ride height
camber
toe
spring rate
damper rate
stabalizer
no stabalizer
width
length
tire
spur gear
pinion gear
lock diferential
gear diferenial
caster
it just some platez of carbon fiber on the out side yu snip the endz and make air plane aluminum partz that are double screw top and or botom miror the same left to right with a hole in aloy for the knuckle and that part iz diferent height on the cylinder that mount the knuckle to alow ride height change with more versionz just like that done even if yu want width change with the same one peice whael az long az yu extend the drive cupz out ward
the spring rate iz cut top and or cut botom spring
the damper rate iz a same spring but weld top and or weld botom
both fuze with a plastic fuze ring that snap in to the damper permament and sit some what tight with the spring above that damper
so if yu have a soft damper stif spring stif stabalizer the car wil bounce quick in a smal road bump
convert this spring system over to the scale
https://www.pinterest.com/pin/447826756680682469/
stabalizer se this photograph
https://s-media-cache-ak0.pinimg.com...779d8dd4c0.png
it just two bar that lock in to a ring with a hole that damper sit above it
with out it iz a plastic and or aloy ring that sit below the damper spring to kaep height corect
diferential
https://s-media-cache-ak0.pinimg.com...14882b2023.png
al the other stuf iz e z to know
the caster stear iz a slide stear bar with the end to each side snip for reverse from the ride height to aloy not it aloy snip to carbon fiber plate that can be length for toe and the rear toe haz thoze that screw in to a low carbon fiber main chasis plate
brakeza
https://www.pinterest.com/pin/447826756680656830/
knucklez one bearing to save weight and bearing pricez and cauze of that yu can uze double axle dog bonez PERFECT
https://www.pinterest.com/pin/447826756680444213/
front bumper mount
https://www.pinterest.com/pin/447826756680440643/
body post mount in to the uper deck that iz one peice al the way from front and or to rear with hole in carbon fiber to pres lock this
https://www.pinterest.com/pin/447826756680473220/
caster iz stear angle caster to
https://www.pinterest.com/pin/447826756680440674/
with wieght to balance car but this bar sit above a aloy angle mount with two ceramic bal then that bar above in the link then two more ceramic bal then the top lock plate to rol with caster
yu slide the front uper carbon fiber angle back for caster and or the botom main chasis plate forward then angle the aloy caster mountz that mount two screw like a triangle in to the carbon fiber if yu se the whael side of this car and laok above the whael the yu se the aloy hole for the knuckle then 45 degrea angle inward toward dif two screw hole that mount that aloy part each about 4.8mm apart in to the carbon fiber above and or below to mount knuckle yu can make theze any caster with the stear slide bar and change height position of cyclinder for right height change with and or with out damper from stabalizer spring damper ratez
dog bone double axle with this
https://www.pinterest.com/pin/447826756680559527/
done for the most part wow wory most part
o
one last thing
https://www.pinterest.com/pin/447826756680643867/
al the gear taeth count are that above and brake caliper hole and rim spoke and tire tread and every gear even in servo and al the bal count in al the bearing
where it change direction from that iz when yu get pinion and or spur gearz az thoze are counted normal number
i cal the kit MINI-Z MA-04
420T2520
jcstuezday is offline   Reply With Quote
January 21, 2006 GTG arch2b Washington DC Area GTG, MD/VA/DC 56 2006.01.29 06:20 PM
Kyosho Scale Strategy alanfujii Mini RC 3 2005.03.05 10:35 AM
1/28th scale , 1/24th F1 scale Midwest Racing Series lightfighter Tracks and GTGs 1 2004.11.15 08:59 AM
Are there really 2 versions of mini-Z F1: One for Jap and another for the rest francis_Z Mini-Z F1 MF-010, MF-015 21 2003.01.15 01:43 AM
Made in Japan or China, what's the diff? MaukaRunner Beginner Questions 12 2001.12.16 04:29 AM
