Old 2016.11.02, 11:30 AM   #1
MiniDeRub
Mini z buggy motor
Hey guys. Just picked up a Mini z buggy 50th anniversary edition with an asf board. Looking to get some advice on motors. Whats the most powerful/fastest motor I can put in the buggy? would it be the Atomic Chilli? Im reading that replacing the Fets or stacking them would be needed in addition to the more powerful motor if so what Fets should I get and how many?
I have a large flat area in the back of my building so hitting top speed shouldn't be too much of an issue.
Thanks in advance
MiniDeRub is offline   Reply With Quote
Old 2016.11.02, 01:15 PM   #2
Before even considering a Chili I would look at the Atomic Stock 48T. it has all the torque which will let you gear outrageously high without needing to change or add fets to the board. The AS 48T geared to say the 4:50/ 4:70 to range will give you more than enough top speed to achieve the "vanishing point". Not to mention the fact that it is many times more durable than the Chili.
Old 2016.11.02, 04:14 PM   #3
MiniDeRub
thanks for the suggestion. Though I would wonder if it be a noticeable improvement over the Xspeed motor it already comes with. I think the xspeed is a 50t
Old 2016.11.02, 06:41 PM   #4
Huge difference. Though a great little motor the X-speed at 54T is not a torque monster while the old 48T Atomic stock is a pocket rocket with tons of torque. I am speaking of the original not the newer round can motors which are great little motors but can be hard on brushes thereby a little short lived without maintenance.
Old 2016.11.04, 09:21 PM   #5
MiniDeRub
I checked and they don't have anything in stock. emailed them to see when they would be getting some but no reply as of yet. I also found this motor chart. Pretty useful for anyone else considering atomic motors. Took a screenshot
File Type: jpg Screen Shot 2016-11-04 at 9.15.53 PM.jpg (422.5 KB, 8 views)
Mini Z F1 motor unclearty Motor Tech 3 2016.03.23 04:30 PM
RR Parts for mini z buggy? d1nzfe Reflex Racing 2 2011.10.31 01:10 PM
shop.tinyrc.com: Back on Track Motor Sale, Mini Inferno Oil Shock BOGO, New AutoScale Mrs Mini-Z Newsletters 0 2011.10.25 10:10 AM
HFAY 70-turn Season 6 Spec Motor Tests schmenzer How Fast Are You? Online Points Series 27 2009.03.09 02:49 PM
HFAY 70-turn Motor - On Track Tests schmenzer How Fast Are You? Online Points Series 1 2008.06.04 06:31 PM
