Old 2016.11.09, 05:16 PM   #1
MiniDeRub
steering issues
I have a mr-03ve and a mb-010 50th anniversary. Im having issues with both of them. first thing I did was get the cars to roll/accelerate straight with the trim. Then, I adjusted end point by turning the cars over upside down and adjusting the end pint until I hear the servo buzzing and then go back 2 notches just to have a buffer. After all this, I find they turn more one direction than the other. Its much more noticeable on my mr03 than the buggy, but I find it weird how they both have the same issue. Which is telling me its something Im doing wrong.
My question is
1- Am I doing something wrong with the adjustments to cause this?
2- If I'm not doing something wrong, what's causing this?
3- Am I expecting too much from these small scale cars?
Thanks
MiniDeRub is offline   Reply With Quote
Old 2016.11.09, 06:28 PM   #2
What radio(s) are being used?
Old 2016.11.09, 06:55 PM   #3
MiniDeRub
Syncro ex-6
Old 2016.11.10, 03:11 AM   #4
Hmm... suggest to do a factory reset on the radio... there's a way to do it on the kt18 but not quite sure how you can do that on the ex-6...
Is the difference in the turning radius between left and right that substantial? Maybe the servo gears are busted? Can't think of anything else...
Hope this helps and good luck
Old 2016.11.10, 11:26 AM   #5
TheSteve
VE7FM
The way you are adjusting the steering end points sounds very logical but on a Mini-Z I would adjust it on track by comparing the turning radius between left and right. It isn't that uncommon that the cars will turn better in one direction versus the other.
AWD from Atomic with steering issues marc Mini-Z AWD MA-010, MA-015 33 2007.06.02 07:08 PM
steering issues Em&em Mini-Z Racer MR-02 2 2005.02.14 04:50 PM
steering issues on 04 Grandpa iWaver 2 2005.02.10 08:23 PM
Knuckle & Steering plate issues..... meblueyz99 Parts and Hop-ups 0 2003.12.02 09:17 AM
fornt servo/ steering issues stuZ Mini-Z Overland MV-01 6 2003.08.01 05:07 PM
