Old 2017.03.09, 08:13 AM   #1
New Kyosho Mini-Z Products 2017
surprised this has not yet started.
Old 2017.03.09, 01:31 PM   #2
autoscales not listed here, they are typically covered in the new autoscale thread.
January
February
ASC MA-020S Nissan Sylvia S13 Warm White Two-tone MZP435WT
ASC MA-020S Nissan 180SX Velvet Blue MZP436DB
Minutes AWD MA-020 Sports Lady Set Mazda Roadster Buriri Flex Mica 【Drift tire standard installed pre-installed】 32137 MB
Minutes AWD MA - 020 Sports Lady Set Mazda Roadster Jet Black Mica 【Drift Tire Standard Equipped Installed】 32137 BK
MZ Monster EX Mad Force Mat Black Lady Set 30093 BK
MINI-Z Racer MR-03VE PRO-W-MM chassis transmitter set 32742
March
Mini-AWD MA-020 Sports Lady Set Nissan SILIITY LED Blue 【Drift Tire Standard Equipped Installed】 32136BL
April
May
Mini-AWD MA-020 Sports Lady Set Nissan Skyline GT-R V.Spec II Nur (R34) Millennium Jade 【Drift Tire Standard Equipped Installed】 32140MJ
Mini-Z Racer Sports 2 MR-03 Series MAZDA 787 B No.55 LM 1991 Readyset 32241 RE
Old 2017.04.25, 08:57 PM   #3
Anyone get data on the ex6 R? It's being shown with the be gt3 rs autoscale slated for june
Old 2017.04.27, 09:58 AM   #4
Traveler
of both Time and Space
Traveler's Avatar
From Kyosho America FB Page HERE
Also, the EX-6R overcame the weak point of the ASF system, which took time to establish connection under heavy radio frequency congestion. In the MHS mode, the Syncro EX-6R can
establish a stable and quick connection with its receiver even in a congested 2.4GHz area, so, there is no more frustration before your race. The R version comes with an Expert grip2 which has thumb control dial and switch, and the new trigger system provides linear throttle feeling. The steering has a steering extension unit with a softer spring for better balance and more linear control.
EX-6R includes the following upgrades:
􀁺 Expansion ver. 2.00
􀁺 Expert grip 2 (with new trigger)
􀁺 Normal extension (with soft spring)
􀁺 Wire handle
Old 2017.04.27, 01:00 PM   #5
unclear if this is a firmware update or hardware? otherwise, this is just an optioned up model. i don't believe MHS is widely in use at this time so not sure who really benefits from the rapid binding in congested areas. great that they addressed this issue but sad that it doesn't include ASF.
Old 2017.04.27, 01:02 PM   #6
Traveler
Traveler's Avatar
It still includes ASF!
Old 2017.04.27, 01:12 PM   #7
to be clear, it does not appear the rapid bind works for ASF as it notes, '...in MHS mode...' this will help the maybe 1% that are running MHS and leave the 99% to make due. Who knows, maybe the new tweak only is compatible with MHS? we simply won't know until someone is able to get more detailed answers.
Old 2017.08.21, 07:51 AM   #8
Minute low-height slick tire (20 / 4 inches) MZW 39-20
[IMG]Option Parts for MR03 / MA020 Used for front tires of Mini Razor and Minute AWD. By reducing the outer diameter of the tire (about 23.6 mm) as compared with conventional high grip tire set (MZW 2) and racing radial tire (MZW 37), it is possible to reduce sticking of the front tire especially in the urethane course, Can be obtained. It was a tire that made it easy for runners to run as well as race users. 20 4 bottles[/IMG]
Minute low-height slick tire (40 / 4 inches) MZW 39-40
40 degree 4 bottles
Minute low-height slick tire (30 / 4 in) MZW 39 - 30
30 degrees 4 pieces
any thoughts on these? you'll have to excuse the poor google translation...
Old 2017.08.22, 05:49 AM   #9
byebye
byebye's Avatar
I guess for those that don't have a tire truer. I wonder how durable they are?
Old 2017.08.23, 07:41 AM   #10
I'm sure we'll find out soon enough, most stores have these already. Other than these tires, just a bunch of re-released kits for coming out.
Old 2017.08.25, 03:20 AM   #11
The advantage of trued tires over these is that they will be the same diameter over the wheel, while these can be installed unevenly. I still think it's a nice option to have, especially if it means less time on the truer, just enough to scuff and even out the surface as opposed to cutting down half the height. Meaning considerably less heat that the tire is exposed to which can change the characteristic of grip.
Old 2017.09.15, 07:37 AM   #12
looks like another limited edition MR-03 MHS kit is coming in November. Oddly enough, it's using the standard MR-02 color scheme as a retro look.
anyone have a clue as to what 'series 4' is referring to?
Radio control electric touring car mini-pro MR-03 MHS / ASF compatible 2.4 GHz system chassis set MR-03VE pro 02 color limited chassis set (W-MM)
No: 32783
JAN: 4548565330447
Release month: November 2017
The MR - 03VE Pro Series 4, which can participate immediately in the race, is
MR - 02 color that brings out a nostalgic atmosphere!
"MHS (MINI-Z (MINI-Z)" boasts an ultra-high response of 16 times the combination of the conventional ASF 2.4 GHz system + KT-18 transmitter and 4 times the combination of the ASF 2.4 GHz system and the EX-1 transmitter made by KO PROPO "Hybrid Spread Spectrum) 2.4 GHz system" as the fourth series of the MR - 03VE Pro series, "02 Color Limited" appeared as a chassis set. The biggest topic of this machine is the car body color reminiscent of MR - 02, which is the predecessor model of MR - 03. By using gray molded parts for blue, main chassis set (No. MZ501) for upper cover set (No. MZ502) and chassis accessory parts set (No.MZ402), visual from one color black MR - 03 normal chassis It renews and creates a nostalgic atmosphere. In addition to the standard equipment of optional parts such as ball differential set and full bearing as with conventional VE Pro, gyro unit is also installed. It is a package that can participate immediately in the race, and the limited model MR - 03VE Pro 02 Color Limited, which looks different from the others, will definitely satisfy your possessive possession. This model is compatible with the conventional ASF 2.4 GHz system and it is automatically set according to the transmitter at pairing, so the Perfex KT-18 transmitter or KO PROPO EX-1 transmission Even users using the machine can operate.
● Brushless motor & gyro unit mounted MR - 03 chassis set
● body color image of MR - 02
● full bearing, ball differential set, gold - plated battery terminal specification
● Mini - z racer full body can be mounted (some body is sold separately motor case required)
brushless motor dedicated board of ● actuated 3 groups LED mounted of at a glance
● coreless motor equipped with the adoption of digital steering servo
● MR-03-based front introduction of the suspension "VCS"
● MR-03 chassis related optional parts It can be mounted to
realize the exceptional operation response by ● overwhelming signal processing speed
Blue and gray molded parts reminiscent of MR-02 are used. A package that can be entered in a race immediately with the gyro unit and ball differential set indispensable in recent races as standard equipment.
Xspeed VE brushless motor boasts outstanding durability and overwhelming high power. Noteworthy point is the elongation in the high revolution range and the flat torque feeling.
Adopted gold plating for motor and battery terminals. As opposed to silver and copper, gold is hard to form an oxide film which becomes a resistance at the time of energization, so it is possible to maintain good conduction efficiency at all times.
Compared with the standard standard differential gears, the ball differential set that provides less stall, smooth differential and smooth cornering is standard.
i would argue the GP version came better equipped but the nostalgic colors are pleasant.
Old 2017.09.15, 07:40 AM   #13
for the R8 fans, the white autoscale is getting a re-release in october!
ASC MA - 010 & 015 Audi R8 LMS White
No: MZP 444 W
JAN: 4548565330294
Release month: October 2017
Old 2017.10.02, 10:24 AM   #14
Thorvald
Thorvald's Avatar
Kyosho Video was released a few hours ago, details here:
http://mini-zracer.com/forums/showthread.php?t=41083
Kyosho Mini Z AWDvs2WD wheels? NYCislander Beginner Questions 3 2017.02.05 09:12 PM
shop.tinyrc.com (Corrected): 10% off ALL MB-010 Products, 40% off Mini Inferno Bodies Mrs Mini-Z Newsletters 1 2012.04.20 10:36 AM
shop.tinyrc.com (Corrected): 10% off ALL MB-010 Products, 40% off Mini Inferno Bodies Mrs Mini-Z Mini-ZRacer.com Announcements 0 2012.04.09 01:14 PM
Kyosho mini z overland hummer h2 readyset monkey19 Mini-Z Marketplace 1 2010.08.12 10:32 AM
FS: Z w/ all Kyosho hopups pchan0 Miscellaneous Discussion 1 2003.06.25 06:50 PM
