Old 2017.05.16, 02:48 AM   #1
NYCislander
Kyosho MR015 Lock rear diff?
Hi I just got a MR015 RTR from a friend in Japan.
Is it possible to lock the rear diff. Sorry if I am getting the parts confused.
Thank you for your time and passion for miniZ R/C
NYCislander is offline   Reply With Quote
Old 2017.05.16, 11:16 AM   #2
RussF
Salt Lake Mini-Z
RussF's Avatar
Sure, but why would you want to? For the stock diff just fill it with putty or glue. For a ball diff just tighten it up.
Salt Lake Mini-Z
RussF is offline   Reply With Quote
Old 2017.05.17, 12:45 AM   #3
Go kart set up? You could open it up and pack in thick grease in there or super glue it to lock it up. I would rather use thick grease instead of superglue that way it would be easier to "unlock"...
Old 2017.05.19, 01:46 PM   #4
NYCislander
Thanks for everyones help
I used the putty trick!
I am trying to drift a 2wd like they do in Japan. However, the car they use is the MR03 with gyro. So, the project is on hold. I believe they have conversions kits but the electronics doesn't support gyro I believe.
Price is another set back. Might be better to just buy a used MR03. I can't use the sport because sport gyro is not as fine tuned with ics.
Thank you for your passion for mini Z r/c
Diff tips thread EMU Mini-Z F1 MF-010, MF-015 7 2016.12.09 06:29 PM
How Can I Provide Clearance For a Car Body So the Damper Post Can Pass Through? Starsky5000 Parts and Hop-ups 12 2011.06.24 06:32 PM
Kyosho Ball Diff in PN Alum Rear Old Crow Mini-Z AWD MA-010, MA-015 4 2008.05.27 07:34 PM
Kyosho Ball Diff Maintenance Nightcargo Mini-Z AWD MA-010, MA-015 4 2007.02.11 03:43 PM
