Old 2017.06.01, 05:28 AM   #1
ko propo multi setting adapter instructions
just got a hold of one... and after searching... found the instructions...
click here
above are instructions for the mr02 module and dnano...
anybody know what the factory settings are for the mr03?
①Data Memory Number
The memory data specified is loaded and saved to the setting card. Eight memory data (1~8) can be retained.
②Load Memory / Save Memory
Press and hold the minus key to load (LD-) the saved data. Press and hold the plus key to save (SAV+) the data. Hold the key until OK is displayed.
③Receive Data / Transmit Data
Press and hold the minus key to receive (RX-) data to the devise. You must save the data to keep it in the setting card. Press and hold the plus key to transmit (TX+) the data on devise to the Mini-Z. Hold the key until OK is displayed.
④Gain (# GAIN)
Holding property of the steering servo is changed. Using the +/- keys, you can adjust the 3 strengths (Min, Mid, Strong). This changes the strength that the servo will keep its position.
⑤Speed (#SPEED)
Change the operational speed of the steering servo. Using the +/- keys, you can adjust the 5 speeds (Slow, 2, 3, 4, Fast).
⑥Punch (#PUNCH)
Change the rate of reaction of the initial movement of the steering servo. Using the +/- keys, you can adjust the punch with 10 different settings from 1 (Low) to 10 (High). When the setting is low, the movement is similar to an analog servo. Adjust to gain the proper control for your settings.
⑦Deadband (#D.BAND)
Configure the width of the neutral zone of the steering servo. Using the +/- keys, you can adjust the 3 widths (Narrow and Wide).
⑧Dampening (#DUMP)
Change the property of the steering servo when it comes back to neutral. Using the +/- keys, you can set it to Smooth or Over. Smooth setting rolls the servo back to neutral and the Over setting applies a brake before returning to neutral, but the movement remains unchanged.
⑨Motor Drive Frequency (#DRVFREQ)
Motor drive frequency of the throttle is changed. Using the +/- keys, you can adjust the 3 drive frequency settings. Mini-Z settings are 1.2/2.5/5.0KHz and d-nano settings are 1.1/2.3/4.8KHz. A low frequency increase torque but decreases runtime and a high frequency gives more runtime.
⑩Neutral Width (#NUTWIDE)
The width of the neutral zone of the throttle trigger can be adjusted. Using the +/- keys, you can configure 3 different widths Narrow, Mid and Wide.
⑪Inertia (#INERTIA)
Adjust the forward movement once the throttle is released. The 5 settings are Strong, 2, 3, 4 and OFF. A setting of Strong slows the carís roll the quickest and OFF allows the car to roll.
⑫Steering Gyro Gain (#ST.GAIN)
The effectiveness of the steering gyro for the d-nano is adjusted. Using the +/- keys, you can adjust the 5 phases OFF, 2, 3, 4 and Strong. The Strong setting will produce the most steering correction by the gyro. Cannot be used with Mini-Z.
⑬Throttle Gyro Gain (#TH.GAIN)
The effectiveness of the throttle gyro for the d-nano is adjusted. Using the +/- keys, you can adjust the 5 phases OFF, 2, 3, 4 and Strong. The Strong setting will produce the most thorttle correction by the gyro. Cannot be used with Mini-Z.
i turned the multi setting adjuster with the mr03 setting card on... and compared to the instructions i noticed that it looked like it had an additional setting... in between inertia and st.gain.... baktime - just guessing time to go into reverse? and it had the following settings....
Data mem#1
ld- sav+
rx- tx+
gain mid
speed fast
punch 2
d. band mid
dump over
drvfreq low
nutwide mid
inertia off
baktime 2
st gain 90
th gain 60
so are these the standard factory settings? you can save up to 8 different settings and "load" them into your car... pretty neat... what settings do you use?
thanks for any reply...
FS - KO PROPO 2.4GHz Mini-Z Module w/ adapter davskee Mini-Z Marketplace 1 2010.09.08 08:32 PM
WTB: ICS Multi Setting Adapter & Setting Card Hekyl Mini-Z Marketplace 0 2009.05.14 07:57 PM
ICS Multi Setting Adapter & Mini-Z 2.4GHz Setting Card Set from Ko Propo Cherub1m New Products 5 2009.03.29 08:11 PM
KO Propo AD Band Roger Setups 153 2007.12.29 04:50 PM
FS: AD band setting adapter pchan0 Mini-Z Marketplace 7 2007.06.05 01:13 PM
