Old 2002.08.27, 02:48 AM   #1
TECHN0
Car spinning toward the right
Hi,
I'm confused as to why one of my car keeps spinning to the right when accelerating. I'm running xspeed with proline rear roll socks and squat ball bearings. New 40 tires by Kyosho.
No hop ups in the front yet and still waiting for my mail orders for some topcat stuff including the bulkhead, tie rods, knuckles, kingpins.
What would I need in terms of stabilizing the front end during acceleration so the car doesn't spins? it is because of way too much torque? I'd think it should leap forward instead right?
Techn0
btw, those squat ball bearings are SwwwwwwwwwweeeeeTTTT!
TECHN0 is offline
Old 2002.08.27, 03:28 AM   #2
jeffrey
undisputed
jeffrey's Avatar
Send a message via AIM to jeffrey
do you have a ball diff.?
FASTEST NON-TURBO RACER!
jeffrey is offline
Old 2002.08.27, 03:58 AM   #3
TECHN0
Yes in fact I do. It's made by Proline I think and it's purple. I forgot to mention that on my post.
Techn0
TECHN0 is offline
Old 2002.08.27, 04:48 AM   #4
butler
Mini-Z Chief
butler's Avatar
Send a message via MSN to butler
Try tightening your diff up. Remember the rear weight distribution is a little uneven because of the motor location is off centre.
Haynes Manual: Prise away plastic locating pegs...
Reality: Snap off...
Haynes Manual: Lightly...
butler is offline
Old 2002.08.27, 05:05 AM   #5
le-manz
Mini-Zter
le-manz's Avatar
Location: Copenhagen-Denmark-Europe-The world-Space-Giants toenail
Also take some time to get the steerring trim on the TX right, and it should be done everytime you turn it on. Well it's one of the flaws of the mini-z
try change the tires to 20, world of difference. if you still experience oversteer then change the fronts to 30 but only the fronts. Tires is by far the most important hop-up for your car so try out some different combinations to see what best for your driving style and surface
le-manz is offline
Old 2002.08.27, 05:09 AM   #6
butler
Mini-Z Chief
butler's Avatar
le-manz, its spins on acceleration. So I guess softer rears will help.
butler is offline
Old 2002.08.27, 05:14 AM   #7
le-manz
Mini-Zter
le-manz's Avatar
lol thats what i meant, but its not coming across very well
what i meant is go for 20 around the car, front and back!!!!!
le-manz is offline
Old 2002.08.27, 05:17 AM   #8
butler
Mini-Z Chief
butler's Avatar
Its all good.
butler is offline
Old 2002.08.27, 03:39 PM   #9
TECHN0
Thanks. Will try to tighten the read diff. Any way of doing this correctly?
Techn0
TECHN0 is offline
Old 2002.08.27, 03:39 PM   #10
TECHN0
Same thing with 20 tires. I think the read traction is too stiff, but then, it should go straight and not just spin to one side right?
Techn0
TECHN0 is offline
Old 2002.08.27, 03:40 PM   #11
TECHN0
I think I'll try that route too and use a softer spring.. But it's weird.. LOL
Techn0
TECHN0 is offline
Old 2002.08.27, 04:20 PM   #12
Russ
Super Moderator
Russ's Avatar
You need to adjust the tweak for your H plate. That is why the car is spinning one way. You said it spins to the right, so the back left tire is getting more traction than the back right. Unscrew the front spur-side screw 1/4 of a turn, then try it again. If you need more, unscrew it again until it is out 1/2 a turn. If you still need more, unscrew the back nonspur-side screw 1/4 a turn. What you are doing when you do this is transfer the weight from the rear left tire to the rear right tire so an equal amount of weight is distributed to both tires evenly. Nothing will cure the problem of a tweaked H plate other than adjusting the actual H plate itself. I've seen H plates so bad that just unscrewing the screws won't help. They even had to put washers under one side of the H plate.
Russ
Russ is offline
Old 2002.08.27, 05:24 PM   #13
TECHN0
Thanks for your advice Russ,
Tweaked meaning bend out of shape somehow? So would changing another H plate cure this? or is it just the nature of these mini-z?
Techn0
TECHN0 is offline
Old 2002.08.27, 07:41 PM   #14
Russ
Super Moderator
Russ's Avatar
Even though they may look it, 99% of the H plates made aren't 100% flat all around. Even if they are, the weight balance from the motor throws it off too. It is highly unlikely that you have the perfect setup right out of the box. So, yeah, your H bar is probably bent, or tweaked a little, you know, twisted a bit. You have to compensate for that little twist.
Russ
Russ is offline
throttle adjustment on the car? Zephyr von Bobo iWaver 9 2006.05.11 08:07 PM
i'd like to have a car i can race on the street, need info! builthatch Off-Topic 16 2006.02.12 01:18 PM
Getting out of Mini-Z racing.... PD2 Miscellaneous Discussion 10 2006.01.19 09:35 PM
A new Stock Car class will be starting this fall at CP Mini RC Raceway Blackno3 CP Mini RC Raceway, NY 58 2004.10.27 09:23 PM
Ideas for sharpening turning radius for 02's bbeattie Mini-Z Racer MR-02 10 2004.06.01 03:15 AM
