Old 2001.12.17, 03:08 AM   #1
PorscheGuy964
House Plant
PorscheGuy964's Avatar
Send a message via AIM to PorscheGuy964
New to the Forums
Hello everyone I am new to this place and just want to say hi, hi.
well I have recently received a mini-z and I love it I think it is so cool. I got the Porsche GT3
Well I joined here 'cause it seems like an active place to post with lots of helpful info.
Right now the only mod I have done to my mini-z is to upgrade the motor to the x-speed motor. the next mod I plan on doing is the ball diff. Does this sound like a reasonable next mod? or is there something that is better?
I currently have just the Porsche GT3 body that came with it and I have recently purchased a Porsche GT2 body I am in the midst of retro fitting to the mini-z chasis.
PorscheGuy964 is offline   Reply With Quote
Old 2001.12.17, 03:45 AM   #2
scsi
scsi's Avatar
Send a message via AIM to scsi
welcome!
ball diff sounds good i would also recommend alloy servo gears later on.
just look thru the forums, theres lots of info for you
never let me slip coz if i slip then im slippin . scsi おげんきですか。
scsi is offline   Reply With Quote
Old 2001.12.17, 07:49 AM   #3
Mondo
Mini-Zedologist - Fear me
Mondo's Avatar
Hot it up
Welcome PorscheGuy964
Yea, I did the bearings first. The The X-Speed motor instructions reccomend that bearings be used with the motor.
Also, being adjustable, the ball-diff can make a difference.
Most of the 'veterans' here also swear by Turbo and X-Speed combo's for pure acceleration with top-end. There are some interesting comments on the other threads about motors and Turbo's. You can learn quite a bit.
As scsi says, alloy servo gears are a good choice as those standard servo gears are prone to breaking (Dont run it without a bodyshell) Also, serious wipeouts can break them fragile stock servo gears too.
Enjoy your new toy!
Old 2001.12.17, 06:53 PM   #4
jrmini
Guest
Posts: n/a
but shouldnt u also get a graphite H plate early on too?
Old 2001.12.17, 11:04 PM   #5
scsi
scsi's Avatar
naw...just wait the the plastic one breaks
Old 2001.12.18, 01:52 AM   #6
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
I kinda agree with scsi. I did it like this.
-Foam Tires. If you get tired of traction you can always switch back.
-X-Speed Motor. You'll be glad for putting foam tires first.
-Bearings. not immediately. drive a few hours.
-Graphite H-plate. Only when you break the stock one. For some that means this is first.
-Ball Diff. If you're racing, go for it. If not, stay stock.
Welcome PorscheGuy964, and say g'bye to your mirrors.
Old 2001.12.18, 02:28 AM   #7
PorscheGuy964
House Plant
hahahah, I have already lost my mirrors on both bodys.
I think if I make another body I will not even bother with the mirrors.
I think I will get the ball diff. since I have the X-speed. I did Just put some wider tires on it(10 minutes ago). The wider tires I got from the model I fitted to it. Now instead of overstear and spinning out alot, it understears and and "pushes". it seems that the car is easier to drive with it understearing but it also seems to bog the motor down when I do try to drift it . with the motor being bogged down will it wear out faster causing me to need to replace motors more often?
Old 2001.12.18, 08:12 AM   #8
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
If the motor or batteries aren't getting too hot I wouldn't worry about it. You can always add heat sinks to your list.
Let's see those custom bodies. Post some pics.
Old 2001.12.18, 03:30 PM   #9
PorscheGuy964
House Plant
I will Try to get some pics up but I don't have a digicam But I do have a scanner so I will have some in a couple of days
Old 2001.12.18, 05:35 PM   #10
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
Yeah scanner. I do the same thing. It seems so stupid but it works sometimes. These were from a scanner.
http://mini-zracer.com/forums/attach...s=&postid=2704
Old 2001.12.18, 10:10 PM   #11
wrcracer
Offroad Specialist
wrcracer's Avatar
i recommend gettin a rear shock set. it solves the rear axle/motor pod/mount hopping problem. i figger if its as bad as it is with the stock motor, its gotta be bad with the x-speed. the shock will keep the rear wheels on the ground and giver you better acceleration. just my 2 cents.
AIM - TheBigGreenGMC
'Wheelin is Life.
WRCRacer's Gallery
Old 2001.12.19, 12:30 AM   #12
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
For something closer to 2 cents, go with the ear plug damper. heh heh
Old 2001.12.20, 08:59 AM   #13
wrcracer
Offroad Specialist
wrcracer's Avatar
WHAT IS THE EARPLUG DAMPER? i cant find what y'all are talkin about.
'Wheelin is Life.
WRCRacer's Gallery
Old 2001.12.20, 09:40 AM   #14
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
You'll find it under "Lightweight Rear Damper" in "Parts and Hop-ups"...
http://mini-zracer.com/forums/showth...=&threadid=181
Salt Lake Mini-Z Club Forums briankstan Salt Lake Mini-Z 3 2008.02.28 02:39 PM
Mini-ZRacer.com Forums Turn 6! mini-z Off-Topic 4 2007.11.11 07:58 PM
Firelap and iWaver Forums arch2b Mini-ZRacer.com Announcements 0 2007.09.23 06:25 PM
TinyRC.com Forums Hacked arch2b Site Feedback 3 2004.06.03 06:31 PM
Copyright ゥ2011 Mini-ZRacer.com
