Old 2002.11.24, 12:48 PM   #1
Waduk
Mini-Z Novice
Alkaline vs Nimh
In my race club, there is a rule, we have to use alkaline batteries when in race.
I found problem uding Alkaline, my car is going slow compare to other car using the same battreries.
A friend of my told me that because I am used to using Nimh batteries.
Any opinion?
Waduk is offline   Reply With Quote
Old 2002.11.24, 02:28 PM   #2
Kinesthesia
Inertial Drifter
Kinesthesia's Avatar
Your car should run slower with alk's than what you're used to running NiMh's. But it shouldn't run slower than other cars running alk's. And if your friend is suggesting that your car is somehow tainted by running nimh and now goes slower with alk's... I don't believe that.
Microracing.net, Mini-Z Information
Kinesthesia is offline   Reply With Quote
Old 2002.11.24, 02:39 PM   #3
Slonik
That's Bunchies!
Slonik's Avatar
Send a message via AIM to Slonik
nimh is pretty much better than alks in every aspect:
Price - you can buy a set and a charger and recharge your batts all you want
Run Time - Ist longer, much longer
Power/Torque - Your car will seem like a friggin' rocket after you switch
Yeah, NiMHs rule!
Slonik is offline   Reply With Quote
Old 2002.11.24, 03:46 PM   #4
Draconious
Draconious's Avatar
Sounds liek some one is giving you the shaft... they are all using NIMH while tricking you into using Alkalines...
there is 100% NO REASON to use ALKALINES AT ALL.. no benifit in any way shape or form... price, run time, or speed are ALL better with NIMH...
1000 hours of Alkalines = 1000 sets of 4 Alkalines at a cost of 1.50 each, or $6.00 a set, or $6,000 every 1000 hours of alkaline use.
With NIMH your only looking at one set of NIMH for 1000 hours of life time (or more) for a maximum cost of 2.75ea cell (and thats over priced) *4 cells for $11 + around 30$ for a Rayovac PS4 1 hour charger your lookign at a big whopping $41.00...
I think 41$ cost less then $6000 dont you? thats a lot of parts for the Mini-Z heck thats a whole second mini-z for a guest car, and 5 or six sets of extra batteries for each one, and two chargers.. and then some....
They have no reason to use alkalines... just give 4 ppl a set of YOUR NIMH and race.. hahaha.
Old 2002.11.25, 01:18 PM   #5
Waduk
Mini-Z Novice
It is true, I am try to change to other alk's, stil slower then other using the same alk's.
My friend, using two x-speed, each for different batteries, it's strange, but I think I will try to buy ones.
Old 2002.12.02, 11:49 AM   #6
Waduk
Mini-Z Novice
Anyone have the same experience?
Old 2002.12.02, 03:31 PM   #7
Draconious
Draconious's Avatar
Sounds like he altered his X-Speed motors -- all ya gota do is open, remove 1 or 2 winds.. and go (risk of frying if u go even less)
Old 2002.12.03, 12:19 PM   #8
Waduk
Mini-Z Novice
I think, not only to one racer, most of it faster then mine.
Old 2002.12.03, 12:34 PM   #9
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
If you're racing just for fun...
(Alks are a waste of money.)
Put some alk labels on a couple sets of NiMh.
And upgrade to stacked FETs.
You'll look like everyone else, until you pull that trigger.
Transmitter Batteries: NIMH AA's OK? Felix2010 Transmitters, Receivers and Crystals 4 2008.01.03 12:31 AM
NiMH Battery Info G-Class Parts and Hop-ups 5 2004.09.09 11:29 AM
2 Nimh + 2 alkaline xalex0000 Beginner Questions 7 2003.09.21 09:37 AM
Alkaline vs Nimh Waduk FAQ 5 2002.11.24 03:46 PM
Charging NiMH batteries. What charger is safe for it? i-WERKS Setups 25 2002.02.16 05:44 PM
