Old 2002.11.25, 08:44 PM   #1
Pedester
Mini-Z Novice
Send a message via AIM to Pedester
Wheel bearing size?
Hey, I need to know the size of the wheel bearings.
I believe its 3x6, but I want to make sure.
Thanks,
Pedester is offline
Old 2002.11.25, 10:24 PM   #2
Draconious
Draconious's Avatar
6mm Outer Dia x 2mm hole x 2.3mm wide
6mm Outer Dia x 3mm hole x 2.3mm wide
Draconious is offline
Old 2002.11.25, 11:54 PM   #3
Pedester
Mini-Z Novice
Which size does the rear take?
(I got mine with a missing bearing, so I want to take care of that.)
Thanks Drac!
Pedester is offline
Old 2002.11.26, 12:33 AM   #4
Draconious
Draconious's Avatar
Those are
Front
Rear sizes...
(4) 2x6 FRONT
(3) 3x6 REAR
Old 2002.11.26, 12:46 AM   #5
Pedester
Mini-Z Novice
..... I need to get back into that car.
I know there are 2 bearings to the fronts,...right?
Then theres 2 bearings in the diff case deal, and one bearing in one of the rear wheels...
Pedester is offline
Old 2002.11.26, 10:47 AM   #6
Karl.no
Tamtech veteran
GOOD GRIEF...
Oi! When you buy the bearings, there's an INSTRUCTION SHEET enclosed. As with all Kyosho option parts. Since ball bearings are the first upgrade one does, I assume you might not know about this sheet. But now you do.
Besides, there's lots of instruction sheets to download on my webpage. Just click the "www" button below, and in you go.
Have fun!
Karl.no is offline
Old 2002.11.26, 06:18 PM   #7
Pedester
Mini-Z Novice
I bought it used, no manuals, no instructions, so I'm kind of shooting in the dark as far as assembly and matenance.
Thanks tho!
Pedester is offline
Old 2002.11.26, 08:35 PM   #8
Karl.no
Tamtech veteran
I'LL MAKE IT EVEN EASIER FOR YOU.
Here's the instuction sheet.
Karl.
Karl.no is offline
Ask IW05's Bearing Size jogxuan iWAVER 1 2008.08.24 09:46 PM
center shaft bearing size enzo1978 Mini-Z AWD MA-010, MA-015 2 2008.03.10 07:51 PM
Need an OFF Bearing Size (for MiX) Draconious Miscellaneous Discussion 3 2007.11.11 04:28 AM
Wheel nut thread size???? MaukaRunner Parts and Hop-ups 4 2003.11.24 01:39 AM
Wheel bearing size? Pedester Parts and Hop-ups 7 2002.11.26 08:35 PM
