Old 2001.12.29, 12:16 PM   #1
Wedginator
Cool Check out this rear shock!!
Hey, This is a rear shock I made my self out of a paper clip.... I didn't have money to buy a after-market shock from the store, so I decided to make one myself.... Hey, This shock works too.. haha
Old 2001.12.29, 02:41 PM   #2
Mondo
Mini-Zedologist - Fear me
Mondo's Avatar
*Shocked*
Wedginator,
Crude but effective! How do you adjust it?
Mondo
Old 2001.12.29, 02:42 PM   #3
T Man
Mini-Z Sensei
T Man's Avatar
Ummmmm.......cool......lol
T Man is offline   Reply With Quote
Old 2001.12.29, 03:10 PM   #4
Wedginator
You adjust it by bending the metal... haha.... It works....
I actually had the cal lowered and it kept on bottoming out, so i put this paperclip on and bottoming out decreased.... heh
Old 2001.12.29, 05:12 PM   #5
Draconious
Draconious's Avatar
I started to do that with my old broken antenna wire, cuz my flash light spring dont realy fit that well with longer susp plates... figured I better not, risk of short if it were to come loose.
Old 2001.12.29, 09:53 PM   #6
Wedginator
Draconious,
hey Draconious, yea, i guess it would be a risk, but if you screw the wire on tight then it would be less risky...
Old 2001.12.30, 12:00 AM   #7
Brett
#1 Drifting Motor Killer
Brett's Avatar
i found a safe way to do it, all you go is get a old plastick buisness card and chop it up in small rectangle then you bend it slightly and place it above your h bar it helps i wish i had a digi cam to show
Brett is offline   Reply With Quote
Old 2001.12.30, 12:23 AM   #8
wrcracer
Offroad Specialist
wrcracer's Avatar
lol. talk about a jerry-rig....
AIM - TheBigGreenGMC
'Wheelin is Life.
WRCRacer's Gallery
Old 2001.12.30, 12:24 AM   #9
Brett
Brett's Avatar
i found an even better way to make a rear shock do the same thing with the card and all but make it in an n shape you can even make it higer if you cut the card longer aslo use a bit of blutack to hold it in place it works great
Old 2001.12.30, 01:02 AM   #10
Draconious
Draconious's Avatar
I guess shrink wrap could solve that, I got lots of small pieces from the sci-plus.com the small wrap has some pretty small diameters, and some are flexible enough. Or could use big fat wire from housing wire... its already insolated.
hmm time to go make a mess in the garage.
Old 2001.12.30, 04:23 PM   #11
Mondo
Mondo's Avatar
Sane Solution
Debble in a real shock!
The look better to
Mondo
Powerline Rear Oil Shock ism Parts and Hop-ups 6 2002.12.10 10:18 PM
360 Modena Rear Shock justtroitin Parts and Hop-ups 16 2002.05.31 10:53 PM
I need help with Rear Shock Question! ricerocketinwa Beginner Questions 6 2002.05.12 05:06 PM
Rear Roll Shock Justin Setups 10 2002.01.19 06:24 AM
Kyosho Rear shock VS Kyosho rear oil damper 323iT Parts and Hop-ups 1 2002.01.14 04:34 PM
