Old 2002.01.04, 07:02 PM   #1
Russ
Super Moderator
Russ's Avatar
servo gear question
Has anyone ever broken the 2nd or 3rd servo gear, or is it always the 1st (or the gear touching the tie rod) that breaks?
Russ
Old 2002.01.05, 12:31 AM   #2
Draconious
Draconious's Avatar
So far Lead gear stripped every occurance, out of 2 strips.
The 9 o-clock tooth on both gears (tooth used while car is going somewhat straight).
useless information:
2nd time I believe was due to poor servo gear mesh, IE bad servo gear, but I doubt I could prove that to kyosho to get a new one, they fit and sounded funny.... then i broke replaced the one, and it was ok again. the one that sounded funny broke while turnning, and no impact was involved.
Old 2002.01.05, 03:54 PM   #3
Mondo
Mini-Zedologist - Fear me
Mondo's Avatar
Servo gear..
Nope Russ,
Always the first one...
Mondo
__________
Old 2002.01.05, 08:00 PM   #4
DAMZer
Zen_gineer
DAMZer's Avatar
Always the first one till I replaced it with the aluminum one.
Over width rims/tires on a narrow chassis + corner rub = 2 broken first gears within 15 minutes. Actually that was the time it took to service the servo and start running again. Went back to standard front rims and tires until I got the aluminum first gear.
Old 2002.01.05, 08:12 PM   #5
Russ
Super Moderator
Russ's Avatar
hehe, I was running the Mini Cooper body with my wide GPM rims...they stick out at least half the width of the front rims....LOL....had a head on w/ F=MA and it went snap....The actual gear didn't break, but the little nub that moves the tie rod broke off. I bet I could super glue it back together.
I put some more pics of my broken parts on my web page, check it from the link at the bottom.
Russ
Old 2002.01.05, 10:10 PM   #6
DAMZer
Zen_gineer
DAMZer's Avatar
Tried that once. Glued it back cause it was a clean break. Drilled a hole through the center and pegged the hole with thin piano wire.
The glue broke loose but the pin held until the nub worked the pin out. Then it was really a mess!!!!LOL What a terrible sound.
Old 2002.01.07, 02:14 AM   #7
i guess i'm quite fortunate enough not to have broken any of my servo gears... that was until my brother borrowed my car....
first servo gear broke.... usually its one of the teeth or the pin that drives the tie rod...
drivers at the track, also break the first servo gear... when they change their first servo gear to alloy, the second servo gear is usually next to go...
Old 2002.01.07, 02:16 AM   #8
anybody here use 3 alloy servo gears? how do they hold up to crashes? and how long do they last?
Old 2002.01.07, 07:02 AM   #9
Cory-Z
Addicted Miniz Enthusiast
Send a message via ICQ to Cory-Z Send a message via AIM to Cory-Z Send a message via Yahoo to Cory-Z
I have 3 anodized blue metal servo gears. Before i bought these, I replaced about...hm...4 or 5 servo sets =)...always the 1st gear of course.
Anyways, the gear are a bit pricey...And some people say the metal gears slow steering. From my personal experience..it didn't hinder steering performance at all. To be honest, The car tracks better, and turning is about as accurate as could be. I don't think those plastic ones mesh too well. They seem like the have a bit of play.
For fun, I tested the durability, and raced around the house..without my shell..yep, that's a no no..hehe
they're indestructible. No apparent damage at all, and they still mesh like they were new.
Porsche gt3/Viper body _ Full spring kit, knuckles, reinforced bulkhead, Kyosho - blue chassis, king pins, 6 spoke (OZ style) wheels, stabilizer bar, X-speed+turbo, bearings. rear shock, side damper, Gpm metal servo gears, etc. etc. basically fully moded -
Cory-Z is offline   Reply With Quote
Old 2002.01.07, 06:26 PM   #10
sonnieshades
Mini-Z Novice
Are servo gears the same for both the mini-z and the F1 or are they different parts?
F-1 Honda
CLK Warsteiner
sonnieshades is offline   Reply With Quote
Old 2002.01.07, 08:21 PM   #11
the f-1 has a servo saver, thus saving the servo gears during really bad crashes. i think they're the same servo gears as the original, but i haven't checked...
Old 2002.01.10, 03:10 AM   #12
hoi
Mini-Z Novice
hoi's Avatar
I am using 3 aluminum servo gears, as my 1st gear broken.
I test these gears for few hours, and it runs good!
I added some Ball Diff oil to smoothen.
hoi is offline   Reply With Quote
Old 2002.01.10, 03:33 AM   #13
just looked, yep they're both the same... both listed as part no. mz8-1...
GPM .. they have many parts.. are they all available? bcuzau Mini-Z AWD MA-010, MA-015 5 2006.03.14 08:12 AM
the 3rd servo Gear fix 2 myzracer Mini-Z Science 7 2003.02.04 12:11 PM
servo convertion killer Mini-Z Science 21 2003.01.03 07:30 PM
-Broken Alloy Servo Gear Survey- Shaun Parts and Hop-ups 9 2002.03.11 01:43 AM
