Old 2003.02.11, 09:58 PM   #1
lowrider035
Mini-Z Novice
Are there any cons to the longer body of the land cruiser?
Are there any cons to the longer body of the landcruiser compared to the pajero?
What are the pros of the land cruiser body compared to the pajero?if any
Is the toyota landcruiser less prone to flip while going around tight corners and on rough terrain than the Mitsubishi pajero.
Are the offroad capabilities of the two Overlands the same?
I hear that the pajero can conquer steep terrain more easily because of it's shorter body length, is this true or are they the same?
Would the longer body of the landcruiser be a problem when going on a relatively steep incline that has some rough terrain on it, would the pajero be better for this?
They are both the same speed right?
Thanks for all of the Help!
lowrider035 is offline   Reply With Quote
Old 2003.02.12, 12:17 AM   #2
Are there any cons to the longer body of the landcruiser compared to the pajero?What are the pros of the land cruiser body compared to the pajero?
>> i got the pajero, my brother got the landcruiser... can't really think of any.. well probably con of the pajero is that since the body is smaller, it's harder to take off than the landcruiser... and both of the body clip/mount came of while i was trying to take them off/on...
>> really haven't tested them enough to cause any flipping... they do skid on smooth surfaces though... i.e. vinyl / wood floors etc.
I hear that the pajero can conquer steep terrain more easily because of it's shorter body length, is this true or are they the same?Would the longer body of the landcruiser be a problem when going on a relatively steep incline that has some rough terrain on it, would the pajero be better for this?
>> basically... they're the same, but because of the shorter wheelbase, the pajero will have a slight advantage since it can go up steeper inclines compared to the landcruizer
>> yep...
hope this helps...
herman is online now   Reply With Quote
Old 2003.02.12, 06:19 AM   #3
lowrider035
Mini-Z Novice
thanks a lot man
Old 2003.02.12, 08:10 AM   #4
biggest difference between the two, the toyota body is a hell of a lot easier to get off.
other than that, the toyota flips less but has a shallower angle of approach and depature due to its longer wheelbase. nothing that can't be overcome by speed! the red pajero body does look the best though.
Old 2003.02.12, 05:33 PM   #5
lowrider035
Mini-Z Novice
even going offroad is the landcruiser less prone to flip than the pajero or is it the same? The pajero looks to have a higher center of gravity so it looks more flippable on offroad terrain.
Thanks a lot guys
Old 2003.02.13, 01:05 PM   #6
379
the landcruiser has better crash protection than the pajero because the landcruiser has a longer body thus bigger crumple zones be4 u blow steering parts or crack diff cases
379 is offline   Reply With Quote
Old 2003.02.13, 02:37 PM   #7
Mondo
Mini-Zedologist - Fear me
Mondo's Avatar
Nice, but no cigar.
None of the Mini-Z's have "crumple zones" (perhaps with the exception of the NSX ) as they are not 1:1 cars, they are plastic shelled RC cars.
Real cars have "crumple zones" as this site will inform you:
http://www.euroncap.com/
Both handle impact fairly well, but the Land Cruiser is a little top heavy and long on the rear end, which can be problematic when tackling steep obstacles.
The steering gear, wheels and lower suspension mounts are well protected and will only get broken if the Overland is abused, as in treated like a stadium truck, which it is certainly not.
The steering gear is only at risk if the Overland is driven without a bodyshell.
Mondo
__________
Old 2003.02.14, 08:17 AM   #8
Digisane
Mini-z Crash Test Dummy
Digisane's Avatar
Crumple zones? Not getting the joke.
I don't get it...
Digisane is offline   Reply With Quote
Old 2003.02.14, 08:41 AM   #9
Mondo
Mondo's Avatar
Re: Crumple zones? Not getting the joke.
Originally posted by Digisane
I don't get it...
Digisane, a few Members reported the NSX bodyshell crumpling when they hit something hard
Hope this clarifies things
Mondo
__________
Old 2003.02.14, 10:06 AM   #10
Digisane
Digisane's Avatar
Re: Re: Crumple zones? Not getting the joke.
Aah thanks for clearing that up. I shall be more aware then. Thanks.
Digisane's NSX - |
Blue Pro-Z Chassis - hard Diamond plate - 3 Castor - 1.5 Toe-in tie rods - alloy rims - bearing motor - Silver 2001 NSX body
New Grave Digger Style Monster Body RTR DogbreathRacing Mini-Z Monster MM-01 38 2005.12.31 09:40 AM
BMW X5 Body Flaw Pete720 Mini-Z Overland MV-01 10 2003.09.13 04:43 AM
Shelby Series 1 Body Justin Custom Bodies 22 2002.02.02 02:28 PM
about the new nsx body..and clk body funkydog Parts and Hop-ups 17 2002.01.17 07:04 PM
A Tight Fitting Body... Corvette Draconious Custom Bodies 0 2001.11.26 12:43 PM
