Old 2002.01.07, 09:54 PM   #1
CTRallyRacer
Mini-Z Novice
Carpet racing setup
I'm going to be racing my F1 and HPI Micro on Ozite carpet, and would like some setup tips for the F1. I was thinking of using the following setup.
Stock chassis
GPM Foam Tires (Foam tire sauce on rear possibly)
Bearings all around
Ball Diff
Any other suggestions would be appreciated!
CTRallyRacer is offline   Reply With Quote
Old 2002.01.07, 11:40 PM   #2
Rick
Raider Nation Citizen
Rick's Avatar
Send a message via AIM to Rick
Sounds good to me, although I'm not sure you'll need traction compound (I'm assuming that's what the "sauce" was) for Ozite. I get enough traction on Ozite with the stock tires and gear diff, maybe that's just me, though. If you are going to use foams, try without the traction compound, first, and go from there.
Rick is offline   Reply With Quote
Old 2002.01.08, 01:17 AM   #3
ruf
4play
ruf's Avatar
What kind of power are you putting down? We just glued down the carpet on our 12'x16' tonight. Traction was good with a stock motor, but Xspeed was a little much for the small track. Traction still seemed good with Kyosho 30s. I haven't tried the foams, but they should be hooked up rather well. I've been running yellow springs all around with gold on the center damper. Basically full stiff. I haven't really had a chance to experiment yet. A guy in the Phillipines is running locked suspension all around and likes it.
Joe Chen
www.reflexracing.net
Houston, TX
Mini-Z World Champions!
Reflex Racing Blog
Reflex Racing YouTube
Old 2002.01.08, 06:14 AM   #4
CTRallyRacer
Mini-Z Novice
Sorry, I will be running on a ozite track that has a 60' straight, then from there it's alot of turns then back on the straight... it's an indoor 1/10th scale track. I'm going to be putting in an XSpeed with 7t pinion I would guess.
Old 2002.01.08, 10:12 AM   #5
ruf
4play
ruf's Avatar
I used to gear 8T for a 70-80' straight, but 7T would have me topped out in 40'. Given that there's a little more roll resistance in carpet, I don't think that there's 20' worth! I think that 7 tooth might be a little short, but 8 would be too tall. You might try playing with different spur gears to get in between.
Joe Chen
Houston, TX
Reflex Racing Blog
Endurace Racing - Setup and Practical tips babstar Setups 6 2008.12.29 02:40 PM
FS: PN Racing AWD silver alloy parts set. pchan0 Mini-Z Marketplace 11 2007.07.16 08:21 PM
The Official Nor Cal Racing Thread Rick Tracks and GTGs 14 2006.08.24 01:47 AM
New Porta-Trax Ozite Mini-Z surface! lornecherry Race Tracks, Track Layouts, Track Accessories 36 2004.01.24 12:41 PM
