Old 2003.04.03, 01:54 AM   #1
Vagabond
Drift master
Vagabond's Avatar
Caster, how much is too much?
I wanted to setup a caster to my MZ. How much caster should i setup? Is 3 degree too much? Any ideas, anyone?
Vagabond is offline   Reply With Quote
Old 2003.04.03, 03:03 AM   #2
are you sure you mean caster? and not camber?
camber can be changed easily by changing the knuckles, caster isn't as easy... i've heard that there's an additional third party optional part...
if you mean camber, it basically is up to you... more camber usually means that it'll be more aggressive / responsive into turns... i've tried 2* and 3*... seems ok
hope this helps...
herman is online now   Reply With Quote
Old 2003.04.03, 10:24 AM   #3
Cian
All Your Base
Cian's Avatar
Send a message via Yahoo to Cian
I've got one of those sets, but I haven't a clue how to fit, as the instructions are in Japanese. Squat make it I think..
[SIZE=1]My Gallery
The Buck Starts Here...
Cian is offline   Reply With Quote
Old 2003.04.03, 06:35 PM   #4
Dougboy
Dougboy's Avatar
camber angle should not exceed 4 degree. 3 would be just fine. in a real car, too much camber would reduce it's braking ability but i dont know what will happen on a miniZ
Go kimi
Dougboy is offline   Reply With Quote
Old 2003.04.03, 11:41 PM   #5
Vagabond
Drift master
Vagabond's Avatar
Yes, i'm definitely sure that i mean caster and not camber....
what is camber and caster? herman Setups 1 2008.03.27 10:38 PM
Wtb Caster Bar (top, Bottom, Or Both) Jebroni Mini-Z Marketplace 1 2008.03.19 10:26 AM
Caster Nightcargo Mini-Z Racer MR-02 6 2008.01.17 07:34 PM
what does a one degree caster on the front steering knuckle mean? kehern15 Mini-Z Monster MM-01 5 2005.04.02 10:33 AM
squat 3 deg caster kit Ko Racer Parts and Hop-ups 4 2002.12.08 05:06 PM
