Old 2003.05.01, 08:58 PM   #1
aaron
aftermarket electronics on a mini z with a pro z chassis
I was thinking of buying a novak spy from tower hobbies with a novak xxl 27mhz am receiver. is this a good combo? i have a eagle turbo w/a pn s02 right now w/stock mini z elecs The stock elec suck big time! Ii would like to keep the esc and rec covered. where are the best deals on this stuff. i have a coupon for 10 buck off @ tower. the spy is 59.99 and rec is 49.99 minus the 10 bucks = 100 out the door. Or should i send my board to mysteyE. please help
Aaron
aaron is offline   Reply With Quote
Old 2003.05.02, 02:58 AM   #2
Pro-Z Racing
Pro-Z Racing's Avatar
Send a message via AIM to Pro-Z Racing
It's all up to the Rules of your Local Track. If you can race with mini z's with aftermarket electronics do it. If not Fet Stacks the way to go. And i would upgrade the Potentiometer in the servo.
Pro-Z Racing is offline   Reply With Quote
Old 2003.05.02, 05:50 AM   #3
tinhead
tinhead's Avatar
Send a message via ICQ to tinhead
Pro-Z: Could you tell us more about that pot-upgrade?
tinhead is offline   Reply With Quote
Old 2003.05.02, 03:20 PM   #4
Pro-Z Racing
With stock mini z electronics my car always had a nervous twitch in it. I upgraded to a better quality pot and now it is solid and predictable most of the time. Still slower than a HS-50 and AM is still prone to radio glitches.
Old 2003.05.02, 08:33 PM   #5
ViperKid
I LOVE WAFFLE HOUSE
ViperKid's Avatar
i'm glad to see that not just my z twitchs
ViperKid is offline   Reply With Quote
Old 2003.05.02, 08:52 PM   #6
T Man
Mini-Z Sensei
T Man's Avatar
Check mine.
T Man is offline   Reply With Quote
Old 2003.05.03, 12:27 PM   #7
tinhead
tinhead's Avatar
Pro-Z: That sounds interesting!
Do you have a part number or such for that pot?
And how much did it cost?
Old 2003.05.03, 01:36 PM   #8
Pro-Z Racing
Tinhead- I got mine from PN Racing sorry i don't have the part number. Try E mailing him I'm sure he has or can get more. I use aftermarket electronics now so theres no need.
T-Man Looks good nice job on the stand up servo. Hows it handle need any setup tips. In mod the dampener really helps rear traction, you will have to mount the electronics on the sides though.
Old 2003.05.04, 08:45 PM   #9
aaron
what electronisc are you using. does any1 know how to use the stock servo w an aftermarket receiver? I mean what wires to put in the plug.
Old 2003.05.06, 03:43 AM   #10
msyko
Mini-Z Enthusiast
You will need to use the board from a micro servo and swap the wires over to it from the stock motor and pot. The motor wire are swapped one for one. Red for Red, Black for Black. The mini-z pot only has two wires on it, you will need to solder an extra wire to it. Use the pic as an example. Not to hard.
msyko is offline   Reply With Quote
Old 2003.05.06, 03:51 AM   #11
msyko
Mini-Z Enthusiast
The completed servo plugged into an XXl receiver. The new board is shrink wrapped sitting on top the the servo. I went with this setup because I broke the servo gears in my HS-50 on my second lap(I deserved that for running it without a body) had an extra stock servo and wanted to keep driving. Works ok for me. You can see the extra wire now coming out of the stock servo.
Old 2003.05.07, 10:56 PM   #12
hpiguy
Mini-Z Novice
Has anyone ever used a real micro servo and an ESC from the ultralight airplanes before?
I have lots of plane electronics and have thought of replacing the electrics in the Z with them. My stock receiver has only a two foot (literally) range so I took all the electrics out and I have lots of room in the chassis.
I was wondering if my 2amp ESC from my planes would handle the power of the X speed motor? Does the X speed draw more than 2 amps? 4amps? 10 amps? It runs for 45 minutes on 700mah batteries so that comes to about 2 amps or so if I did my math right.
Anyway the open hole where the servo was is large enough to hold a micro servo (22mm X 11mm), the ESC and a micro receiver (Tekin AM 75mhz).
Do you think it would all work? The ESC has only forward, but if I hook it inline with my Turbo it should have reverse through the turbo. No? Afterall the turbo just receives the signal from the ESC and takes over after that.
Give me your opinions. The only hard part about installation would be the servo mounting to the steering but I figure tha if I drill a hole through the steering arm, and use a micro bolt and nut to mount it to the servo arm it should work.
hpiguy is offline   Reply With Quote
Vital Statistics arch2b Autoscales, Bodies, Cars and Drivers 40 2007.08.14 10:30 AM
My custom mini chassis design... Draconious Mini RC 9 2003.08.10 11:26 PM
Installing 1/10th Scale Electronics in the Mini Z Racer CTRallyRacer Parts and Hop-ups 2 2002.03.04 08:55 AM
mini z lite electronics egriffith45 Beginner Questions 3 2002.02.28 07:19 PM
