Old 2003.08.26, 10:58 AM   #1
Zephyranthes
Like the Wind
Zephyranthes's Avatar
Send a message via AIM to Zephyranthes
Using Mini 4WD motors?
Can you use Mini 4WD motors in a Mini-Z and vice versa?
Topcad alloy motor mount, Kyosho 12t pinion, GPM alloy servo gears, Topcad roll shocks, Kyosho rear damper, Kyosho X-speed, dry bearings, GPM alloy rims, GPM alloy flanged nuts, Kyosho clear chassis, GPM steel h plate, GPM 10 deg radials, GPM alloy knuckles 1 degree camber, and Topcad alloy steering bar 1 degree toe in, Kyosho ball diff, Wedgy's carbon fiber bumper
Zephyranthes is offline   Reply With Quote
Old 2003.08.26, 01:25 PM   #2
miketre
Yes and No.
Use the search button to find out why
miketre is offline   Reply With Quote
Old 2003.08.26, 03:20 PM   #3
Draconious
Draconious's Avatar
There is no tamiya motor that you can justput in the Z and go... even the ones that are "safe" for the electronics, need the cheap brushes changed to better ones... just buy an X-Speed, the tamiya motor is basicly the same as the X-Speed...
Old 2003.08.26, 05:59 PM   #4
miketre
If you have FETs/turbo, you can go up all the way to the Hyper Dash 2 (35 turns). Don't try anything hotter, or the tracks on your PCB will melt.
If you are running the stock FETs, the Atomic tuned (45 turns) is near the limits of the FETs. Some ppl used it on their stock Zs and burned the FETs, others have no problems. YMMV
Like Drac said, change the copper fingers that come with the Tamiya motors to carbon brushes.
btw: Your question have been answered many times before. You just need to use the search button.
Cheers!
mini 4wd Motor Installed gaowee Beginner Questions 35 2006.12.05 06:28 AM
tamiya 1/32 mini 4wd stuff new wanted anyone that can sell? Simoncino Parts and Hop-ups 0 2006.06.30 10:46 AM
tamiya 1/32 mini 4wd parts and cars wanted! Simoncino Off-Topic 7 2006.05.28 03:19 PM
Tamiya 1/32 Mini 4wd Parts And Cars Wanted! Turbo Dash Motor Simoncino Miscellaneous Discussion 1 2006.05.26 11:27 AM
