2010.01.13, 07:57 PM
MR-02 for life
At home practice with tiny, or no track
Well, I am coming to the sad conclusion that I'm limited to going to the track one time a week. I'm grateful that I can go that much, but I know that with such limited track time it is going to be hard to progress and impossible to perfect.
So I'm trying to figure out the best way to get wheel time, and how to get into the A-Main
My situation is this:
* I have a tiny apartment and could only setup a track on a temporary basis. Max size of track is probably 10x6, but realistically I could only do 8x6 or maybe even 6x6.
* I have limited time because I am fortunately working full time(I started a job on Tuesday, after months of looking, yay!)
So I've been thinking about this a lot and what I've come up with for options is this:
* Get a Mini-96 and set something small up once in awhile.
* Get a dNaNo and a rollup track
* Get a Micro-T and drive it outside
* Get a 1/18 or something of that ilk and drive it outside
My thoughts on these options
* Mini-96 running mini-z would be identical to real track time, but tight. Downside is that setting up the track takes a long time, and I'm not sure how often I'd do it.
* A dNaNo would be *SWEET* and a rollup track is easy to setup, under 10 minutes. however, these little guys are not cheap and everything has to be mail ordered. Kind of a pain.
* A micro-T in stock form is cheap, but to have FM or SS electronics is just as expensive as a dNaNo. Running outside would be fun, but not very similar to mini-z..........
* Something else. I have no idea, haven't really looked into it.
So.. yeah, just stream of conscience here.
2010.01.13, 08:21 PM
You can always get a VRC simulator... Im in the same boat as you, trying to figure out what to do as well.
2010.01.13, 08:28 PM
MR-02 for life
I'm surprised you didn't comment on the Micro-T, because I know you have one. What are your thoughts?
Are the VRC's realistic enough to benefit you?
2010.01.13, 10:43 PM
RC addict
does your office have "space" that you could set-up a track?
invite officemate into the hobby and run it on break time or before office (you get to go to the office early) or after office (you get to stay at the office late)....
2010.01.13, 11:21 PM
From my experience with a bare Mini-96 its a VERY short track. Feels like I get used to it much faster than to a typical 2 Wide L or more, so while you'll be able to hone your skills the cap for that might be a fairly low. Thats my thoughts so far.
New site.
2010.01.14, 12:15 AM
The Galliant Dude
I have a micro-t and I dont think it helps much with driving unless your really a novice. They are kinda fun though outside.
2010.01.14, 12:32 AM
I wouldnt get a small track for the mini-z.
t is totaly different then driving on a bigger track. You wouldnt get anything out of it other then maybe testing some new tires to see how much grip they have.
2010.01.14, 10:15 AM
Actually, properly stored, the Mini-96 wouldn't take any time at all to set up. I have about a 15'x20' track in my garage stored in sections and I can set it up in less than 10 min.
Another option you didn't mention would be to use the $$$ you're raking in from your new-found job to get a bigger place!
It just depends on what you want to do. Bashing larger scales around outside is fun, but bears little relation to track time with Mini-Z's. Ditto the rollup track and Dnanos. Do you want to hone your Mini-Z skills, or just have some general RC fun?
ianc
2010.01.16, 12:33 AM
MR-02 for life
Still thinking about this. I haven't driven an RC since Saturday, and it is bumming me out.
I did some research into the virtual RC racing, and the VirtualRC software is supposed to be very accurate. If I got the USB adapter I could use my EX-10 too, which would be nice. Another upside is that I wouldn't have to spend time wrenching on any other cars...
However, it doesn't seem nearly as desirable as running a dNaNo....
Action B, well, i'm not that much of a novice any more.. I've won a couple B mains now. I think the micro-T would be drastically different than the Z, but if I drove the thing on a fixed track and timed it I think I could work on my line etc. Of the physical car options I feel like that would let me get the most real driving time...
The more I think about this the more I think I should check out the VRC...
2010.01.16, 12:44 AM
Guest
Hey Jeremy I'm in your shoes.. I'm getting a mini-96 since I have the room. I'll take some pics of a layout once it comes in..sound cool?
2010.01.16, 09:03 AM
MR-02 for life
Yeah, very...
I saw that atomic mods sells the 50cm RCP tiles individually. I think for $3.99 which isn't too bad. For a dNaNo I figure you'd need a 4x2 tile setup to have something worth practicing on. That comes out to just over $40 shipped to my zip, and could be pretty good. Too small for a Z though.
-Jer
2010.01.16, 02:06 PM
Blank track, and make your own borders would be the best way I think... Although, finding the right border material then becomes the biggest problem... I would run on the smooth side with the Dnano though.
2010.01.16, 02:23 PM
Honda Insight Racer!
If you have space for a Mini96, that is the way to go. It is a tight coarse and the DNano is perfect on it. If you can successfully race around the Mini96 without hitting the walls much, your pretty good to go. I wouldn't try a Z on the Mini96 as it's a very tight track for 1/28 scale, but it's perfect practicing for 1/43.
A Micro-T is a very different animal and it's more for bashing around and jumping about than flat-out racing.
I highly recommend the office deal and maybe you can have a more "permanent" location than at home. Plus, if you can get your co-workers in on it, it's better practice to race with somebody than on your own, and it's a lot more fun to. Plus, it gives you something to look forward to other than just work! Wish I had a job like that!
Good luck!
2010.01.16, 06:35 PM
MR-02 for life
Yah. Who knows... BLAH!
I'm tired of thinking about it right now.
2010.01.16, 09:24 PM
The name is Tim
best to go to the place you racce for practice. best bet is to go on a non race day and set up the car. you can probably run for a couple of packs.
