Old 2002.08.23, 02:02 PM   #16
Strider-
Strider-'s Avatar
Well it says that the big piece is the middle plate...........
Strider- is offline
Old 2002.08.23, 02:04 PM   #17
Strider-
Strider-'s Avatar
ehehe nevermind
the only thing i can clearly see on the package are just the contents etc.........
Strider- is offline
Old 2002.10.02, 12:53 AM   #18
Russ
Super Moderator
Russ's Avatar
Send a message via AIM to Russ
Hey guys, so about this caster kit...
It doesn't adjust any characteristic of the car at all. I have seen it sold as "caster kit" and "adjustable front end kit". I see how it is an adjustable front end kit because you just remove the top plate and can replace the springs very easily. However, That is the only thing different from the stock bulkhead. Unless there is something I am missing, which I'm pretty sure I'm not, this kit doesn't change / affect anything on the car.
I fooled around with it for about 30 minutes and couldn't see how it could possibly change anything. The kingpin holes are exactly where they would be on the stock bulkhead.
www.skateescape.com/russ/miniz/adjustable.zip
** edit: I know someone's gonna ask... that is a dummy servo case, no internals. That's why my steering is all funny. My ESC is getting the internal turbo upgrade done, and the servo is kinda hooked to it! I just wanted to build up this front end kit and see what it was all about. **
Russ
Russ is offline
Old 2002.10.02, 01:42 AM   #19
Adrian
Adrian's Avatar
i am 99% sure that / \ is camber but i have no idea wat caster is
Adrian is offline
Old 2002.10.02, 01:55 AM   #20
jeffrey
undisputed
jeffrey's Avatar
Send a message via AIM to jeffrey
the two words camber and caster mean the same thing!
FASTEST NON-TURBO RACER!
I DON'T NEED A FAST MOTOR TO GO FAST!
jeffrey is offline
Old 2002.10.02, 03:11 AM   #21
camber - looking straight at your car from the front view (with the body off) the wheels will look like / \ meaning the top of the tires are closer to each other than the bottom
caster - looking at your car from the side (car direction ---> or going to the right....) no caster the kingpin is parallel to the ground or I ..... with caster it's tillted towards the left or \
basically the main purpose of each is to attack corners more aggresively... not quite the same, but more or less serves the same purpose.
herman is offline
Old 2002.10.02, 04:14 AM   #22
butler
Mini-Z Chief
butler's Avatar
Send a message via MSN to butler
hermans right.
castor is like dynamic camber, it increases the camber the more steering lock you add.
camber is the same all the time.
in the real world castor is better because it doesn't wear the insides of your tyres.
off road 1/10 buggy use loads of castor
Haynes Manual: Prise away plastic locating pegs...
Reality: Snap off...
Haynes Manual: Lightly...
Reality: Start off lightly and build up till the veins on your forehead are throbbing then re-check the manual because this can not be 'lightly' what you are doing now.
butler is offline
Old 2002.10.02, 06:53 AM   #23
Wedginator
Send a message via ICQ to Wedginator Send a message via MSN to Wedginator
You mean perpendicular?
Wedginator is offline
Old 2002.10.02, 09:04 AM   #24
2EZ
Mini Z Driver!
2EZ's Avatar
Send a message via AIM to 2EZ
One of castors main functions is to return the steering to center or to help do this look at a caster on a rolling chair when it changes direction it automatically lines up with the direction of travel Caster moves the contact spot forward or behind the pivot point as on a motorcycle. Camber helps to keep as much tire on the ground as possible as the suspension works it counteracts weight and torque as they react with the auto when in motion. A lot goes on while an auto is in motion. Caster, camber and toe are all different but basically work to keep as much of the tires print interacting with the road surface as possible.
2EZ
2EZ is offline
Old 2002.10.03, 12:38 PM   #25
El Padre
Mini-Z Novice
Send a message via ICQ to El Padre
http://www.teamxray.com/teamxray/pro...&kategoria=253
El Padre is offline
Old 2002.10.08, 12:37 PM   #26
Russ
Super Moderator
Russ's Avatar
Ok, so maybe I was wrong.
Mini-Z Admin just got a fax from the Pres. of Squat and it said that there is 3° of fixed caster in this set. I measured as best I could, and it looked like the holes were in the same spot as on the stock bulk head, but I guess not.
So, this product is not mis-labeled in any way. I can't wait to get my ESC back from the FET upgrade to give it a run!!!
Russ
Russ is offline
what is camber and caster? herman Setups 1 2008.03.27 10:38 PM
Wtb Caster Bar (top, Bottom, Or Both) Jebroni Mini-Z Marketplace 1 2008.03.19 10:26 AM
Caster Nightcargo Mini-Z Racer MR-02 6 2008.01.17 07:34 PM
Caster, how much is too much? Vagabond Setups 4 2003.04.03 11:41 PM
squat 3 deg caster kit Ko Racer Parts and Hop-ups 4 2002.12.08 05:06 PM
Copyright ©2000 - 2025, Jelsoft Enterprises Ltd.
