Old 2004.08.20, 02:09 AM   #1
revzalot
MR02 PCB into a F1
Can you stick a MR02 PCB into a F1 chassis? What connections are needed to be done. Thanks in advance.
revzalot is offline   Reply With Quote
Old 2004.08.20, 05:05 AM   #2
davisdavis
i think u can~ (not sure)
the pcbs of all the minizs are actually the same dimension, jsut that the components on the board are soldered on different sides.
i transplanted my mr02 pcb to a mosnter and it woks perfectly fine.
davisdavis is offline   Reply With Quote
Old 2004.08.20, 08:21 AM   #3
Capt. Oversteer
Capt. Oversteer's Avatar
I don't think the 02 board will work on the F1, the crystal placement is different.
You can never turn too soon or too sharp
Capt. Oversteer is offline   Reply With Quote
Old 2004.08.20, 10:08 AM   #4
hmm... i don't see the logic of putting the mr02 board in the f-1... in my opinion the f-1 board seems ok... and as capt oversteer mentioned the crystal placement is different
Old 2004.08.20, 10:48 AM   #5
davisdavis
the only thing that the MR02 is better than all the other PCBs is that it can accept up to 10V power supply.
this 10V is not about the motor or the FETs, the 10V seen on the mr02 pcb will allow you to use powersupply up to 10V while not affecting the receiving.
if u use 6 -8 cells on other pcbs, the steering will shake a lot more often
Old 2004.08.20, 10:52 AM   #6
TNB
Pet Human
TNB's Avatar
Besides the new F1 board is different from the old F1 board; however, my guess is that one reason the board was changed was because of the radio change. For those in doubt, I uploaded comparison photos of the F1 boards to Gallery TNB sometime ago. You'll notice one component missing on the new F1 board which also doesn't appear on the MR-02 board--a small silver box with an adjustment. If that box has nothing to do with the older radio, I'd appreciate someone explaining to me what it was for. My next question then is would that also mean that the older F1 board actually have more options or adjustability than the newer F1 and MR-02 boards?
Gallery TNB
Old 2004.08.21, 02:19 AM   #7
gulfclk
CT03 is coming ...
gulfclk's Avatar
My F1 PCB was broken a while ago, and I've put a new MR-02 PCB on my F1. Yes, you need to place the christal holder in a different position, but that is quite easy to do. Heat the 2 points of the chrystal holder sticking out from the back at the same time and them push them out together. Reconnect them again using small wires ... like done on the real F1 PCB.
After that, you need to make the wires for the on/off switch longer as they will be too short. For the rest, it all fits fine.
I don't see why you want and 10 Volt PCB on a F1 ... there's no extra room for extra batteries any way.
I thought the MR-02 PCB would have more punch than the F1 PCB (which is the case for MR-01 and MR-02 PCB, the MR-02 is more punchy), but it did not change anything.
If you're feeling everything is under control, you're going too slow!!!
CT-03 RULES!!!, Renault F1 2004 version full option, MR-02 RM full option, BMW X5 on MR-01 MM chassis
[COLOR=DarkOrange]
gulfclk is offline   Reply With Quote
Old 2004.08.21, 04:18 AM   #8
Ninja
Mechanic
Ninja's Avatar
if you run the CP car conversion then there is plenty of room for extra batteries
Real Racers Do It Sideways.
Old 2004.09.14, 03:15 PM   #9
pHREDD
z of mini
pHREDD's Avatar
BUt if you fry an F1 board I have never seen a replacement board. The only option I can see is the MR02 board with the crystal change. I have recently acquired a MR02 board that I plan on installing in my F1 (the old F1 board has become my practice board and is beyond repair).
pHREDD is offline   Reply With Quote
Old 2004.09.14, 04:56 PM   #10
Ninja
Mechanic
Ninja's Avatar
there are replacement F-1 boards at RC Mart/ DIN BALL
Old 2004.09.14, 06:28 PM   #11
pHREDD
z of mini
pHREDD's Avatar
HHHmmmm...I looked there and didnt find any
Old 2004.09.15, 12:37 AM   #12
Ninja
Mechanic
Ninja's Avatar
i cant find it now, but i saw one somewhere the other day. maybe it was on ebay
Old 2004.09.15, 01:44 AM   #13
Ninja
Mechanic
Ninja's Avatar
ok i found it, it was at tower. it is $99.99, you would be better off getting a whole used F-1 at ebay, but here is the link anyways http://www2.************.com/cgi-bin...?&I=LXAVX3&P=7
Old 2004.09.15, 12:49 PM   #14
mini-z
Administrator
mini-z's Avatar
Email us at shop@ and we'll beat that Tower price the same way we do on all PCBs!
Old 2004.09.15, 11:06 PM   #15
cosmo_k
u know you could reply alot earlier next time minizracer.... woulda got one off ya's...
i would buy here over anywhere else- but response is kinda slowish- no offense- but your shipping kicks butt!!!
btw- are you guys planning to put in an express shipping option for overseas - or am i just blind to see it??
cosmo_k is offline   Reply With Quote
mr02 pcb board dohc Mini-Z Marketplace 6 2007.10.23 08:39 PM
Wtb Mr02 Pcb SuperFly Miscellaneous Discussion 2 2006.05.30 08:44 PM
WTB new or barely used MR02 or PCB michvin Mini-Z Racer MR-02 7 2005.11.12 11:09 AM
MR-01 PCB on a replacement MR02 chassis Cian@work Parts and Hop-ups 26 2003.10.04 07:40 AM
